Community Member
CME Extension Mobility and ephone-template question
  The Extension Mobility section of the CME admin guide has the following note:
" Templates created using the ephone-template and ephone-dn-template commands can be applied to a user profile for Extension Mobility."
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html#wp1162977
but there is no detail or example of how this is achieved.
Does anyone know if this is possible and if so, how?
Phil
Hi Phil,
It mean that when you create "voice user-profile" for Extension Mobility service
You will need to assign a needed softkeys and any other option
You can use ephone-template for this
As ephone-template 1
Then under all required voice user-profile, you can apply this ephone-template to them
Voice user-profile x
ephone-template 1
Haitham
Community Member
Hi Haitham,
What you say seems logical and something I have already tried but the option of configuring an ephone-template under a voice user-profile is not available in the CME versions I have tried.
I would be interested to know if you have have you actually got this working on a CME and if so what version ?
Phil
213
