CME extension Mobility + permanent number for phone
Is there a way to configure CME to allow a phone to have a permanent number and still let a user login to the phone using extension mobility, so essentially the phone has 2 numbers when someone logs into it, and still has the permanent number once a user has logged out?
Kasun.
Everyone's tags (1)
I have already added the
I have already added the supposed permanent number to the log-out profile BTW...
If you mean you want to let
If you mean you want to let anyone log into EM enabled phone with DN 1000, log in, and end up with DN 1000 + their own EM DN, no, there is no way to do that. The non-EM config is not used to build up the EM, they're static configurations, this would only work if you only use that phone, and have DN 1000 in your EM profile, defeating the whole purpose of using EM.
java
if this helps, please rate
www.cisco.com/go/pdi
40
