Community Member
CME Failover
CME failover
What would be the best way to implement failover in a standalone cme system.
My thoughts so far are :
Identical router minus the modules but with the same config
In the event of failure of the primary router
Remove modules and install in standby router
Present fxo lines and E1 lines to standby router
or
Identical hardware running hsrp
Present lines into hot standby router
Caveats no voicemail ?
Looking for the best solution with minimal downtime
Anybody running any similar sort of implementation ?
Hall of Fame Super Gold
Re: CME Failover
Hi Mark,
HSRP will not help because phone need to register to the address specified under "telephony-services", not HSRP address.
Now CME also supports redundancy, that is indicated in the lastest feature guides, and that is what you would need to use.
Hope this helps, please rate all useful posts
Community Member
Re: CME Failover
That is not right you can do HSRP with CME for redundancy. You will have to have CUE in each router and config changes will be manual. telephony service will point to the virtual IP address
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps4625/products_installation_guide_chapter09186a008054bc91.html
Srini
298
