CME Fails on cfwd noan to CUE with Disconnect Cause 41
r.stockton
I have a multi-site, multi-cme deployment.
CME versions 7.x
Site A: CME/CUE
Site B: CME/CUE
Site C: CME - uses Site B CUE
Among other things :), intermittently, calls are failing to VM on calls directed to Site C: but fwd to Site B:
Calling Number = 313 (Site B:)
Called Number = 777
call-forward noan *400 timeout 3 (3 for testing, 14 live)
Ext. 400 resides on Site B:
Ext direct-to-VM number is *400
When setting call-fwd all *400 I am unable to repeat the issue
When setting cfwd-noan *400 I will hear ring busy sometimes.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
no supplementary-service h450.3
supplementary-service h450.12
ephone-dn 55 dual-line
number 777
label Loans
description Loans
name Loans
preference 1
huntstop channel
no huntstop
I have attached output showing the output of deb ccsip messages. Note the disconnect cause code on the bad call. The good call was placed one minute later.
So, I guess the best question is...how to troubleshoot disconnect cause 41?
Thanks!
6 Replies 6
The debugs is actually just the CDR output, so it doesn't help much.
I'm guessing you're running CME between the routers?
Have you tried adding this to both:
voice service voip
no supp sip refer
no supp sip moved
allow-connections sip-to-sip
-nick
paolo bevilacqua
There is no debug ccsip message in the attachment.
oops, debugs included this time.
Can you describe the logic of the following:
no supp sip refer
no supp sip moved
Also, should SIP to SIP be on both CMEs?
Before I read further, for voicemail CME C uses IP address of CUE B, not CME B, correct ?
Correct. Site C used CUE IP address.
This may be dsp related since g.729 is being transcoded for VM. Trying to figure out how to prove this, though....
