CME Faxing Question - 2901 Router
We just put in a Cisco 2901 router as our CME/CUE solution with two WIC slots (4 analog ports on each).  This replaced an ICS 7750 solution.
We also have 15 DIDs. I would like to set up one of the DIDs to ring on one of the WIC ports, where a fax machine will be connected to.
Any guidance here would be greatly appreciated.
Phil
1 ACCEPTED SOLUTION
Re: CME Faxing Question - 2901 Router
If your provider sends 10 digits, do this:
dial-peer voice 3011 pots
destination-pattern 6471234567
port 0/2/1
Destination-pattern is the string we use to match for an outbound dial-peer match.  You're essentially assigning the DID directly to the phone by doing this.
EDIT: Removed part about CM, since this is a CME install.  Make sure you have direct-inward-dial configured on your inbound dial-peer match for the POTS side.
If you have issues, run:
debug isdn q931
debug voip ccapi inout
debug vpm sig
Be more clear: where are your DIDs coming in?  Is that from a PRI?  SIP trunk?  FXS DID?
I assume when you refer to your 'WIC' ports those are FXS ports.  To get the FXS to ring you simply need a POTS dial-peer pointing to the fax machine port, with a destination-pattern to match the length of the DID that is coming in from the DID circuit.
My aplogies. I'm a bit new to the backend CLI configuration. I've only worked with the front end GUI.
The DIDs are coming in from a PRI. And yes, I mean FXS ports.
I take it the diap peer would look like this:
!Analog fax machine
destination-pattern 3011
port 0/2/1
What would the corresponding destination pattern be to match the above? The phone company is sending 10 digits. 6471234567 would be the DID in question.
Also, is there a particular significance to the "3011"? Or, can that number be anything as long as its unused?
Phil..
port 0/2/1
debug isdn q931
debug vpm sig
Perfect.
That did it!
Thanks!
Phil...
410
