CME file
hello,
i order a cisco 2911 router with smart net and S29UK9-15204M, FL-CME, L-CME-SRST-5 and 21 ip phone 7821
i want to ask are the cme files come with a router or i must buy it.
thanks a lot
1 REPLY
CME is embedded in the IOS,
CME is embedded in the IOS, you only need to buy licenses
java
if this helps, please rate
www.cisco.com/go/pdi
78
