CME: Force an IP Phone to dial to a specific voice-port
Greetings,
How can I get an IP Phone to dial out using a specific voice-port or voice-ports?
David
1 ACCEPTED SOLUTION
Re: CME: Force an IP Phone to dial to a specific voice-port
See the following link for an explanation and sample config.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Hope this helps.
Brandon
Hall of Fame Super Gold
Add a dedicated DN for picking the desired line, and put it on dedicated lines button.
Then, use the "trunk" command in ephone-dn, and match that number in a pots DP with the desired port..
Hope this helps.
Brandon
199
