CME forward call
Hi guys,
is there any way for CME to forward the destination number to the next CME
for example
SiteB--------SiteC
|        Fa
|WAN (se)
SiteA
siteA number 1000
siteB number 2000
siteC number 3000
3 sites (A, B and C), from siteA I would like to call siteC.
However, on siteA's CME I bind the session target with SiteB's IP and siteB will forward the call to siteC
the config so far more less like below
SiteA
dial-peer voice 2000 voip
destination-pattern 2000
session target ipv4:RouterB
codec g711alaw
dial-peer voice 3000 voip
destination-pattern 3000
codec g711alaw
SiteB
dial-peer voice 1000 voip
destination-pattern 1000
session target ipv4:RouterA
codec g711alaw
session target ipv4:RouterC
codec g711alaw
dial-peer voice 1 voip
incoming called-number .
codec g711alaw
I think that the command "incoming called-number ." will do the trick, but it still doesn't work.
Again I assume that it will be similar config as pots
dial-peer voice <tag> pots
direct-inward-dial
port 0/0/0:00
Please advice
Thanks in advance,
Terrence
1 ACCEPTED SOLUTION
Silver
Re: CME forward call
You need to have following command on SiteB Router
Configure terminal
voice service voip
  allow-connection h323 to h323
Hope this helps
- abu
Silver
Configure terminal
voice service voip
Hope this helps
- abu
Thanks abu, it's worked !!
really appreciate your help
Again. thanks heaps
150
