CME - Forwarding an incoming call to an external dest (ISDN)
Greetings,
I am having trouble forwarding an incoming (ISDN BRI) call to an external (same ISDN BRI) destination. Any help is greatly appreciated.
I have an extension 794 on an IP Phone. It will act as an attendant phone. It will be used to forward to a group of phones by extension 100 (using overlays). When everybody is gone, the extension will have a CFWDALL to an external destination.
1) Incoming ISDN calls to the IP phone work.
2) Outgoing calls from the IP phone to ISDN work.
3) Another IP phone calling the IP phone with an external CFWDALL destination works.
4) Incoming call being forwarded to the external destination via CFWDALL doesn't work.
The cause code is:
Cause i = 0x82E46C - Invalid information element contents
I suspect that the Telco doesn't like my outbound calling number (which is the same as the inbound calling number). However, I would have expected a cause code of:
Cause i = 0x829C - Invalid number format(incomplete number)
I thought I'd have handled the calling number issue with my translation profile 111 below....
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME - Forwarding an incoming call to an external dest (ISDN)
Your CO is indeed a bit strange, as it doesn't disconnect immediately.
However, try
interface bri 0/0
isdn map address . type unknown plan unknown
Then, you should use isdn tei-negotiation preserve, configure trunk-group if using both BRIs, I also think you don't need to use 0 for a PBX in the Netherlands, due to the fact that all numbers begin with 0 or 1.
The shortened config:
isdn switch-type basic-net3
isdn tei-negotiation first-call
voice service voip
no supplementary-service h450.2
no supplementary-service h450.3
h323
voice translation-rule 110
rule 1 /^.*/ /294233794/
voice translation-rule 111
rule 1 /^1../ /0294233794/
rule 2 /^737/ /0294234737/
rule 3 /^794/ /0294233794/
voice translation-profile 110
translate calling 110
voice translation-profile 111
translate calling 111
voice translation-profile outgoing
translation-rule 1
Rule 1 ^.% 00 national national
Rule 2 ^.% 000 international international
interface BRI0/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/1
no ip address
shutdown
isdn static-tei 0
voice-port 0/0
translation-profile outgoing algemeen
translate calling 1
compand-type a-law
cptone NL
bearer-cap 3100Hz
voice-port 0/1
translate calling 1
compand-type a-law
cptone NL
bearer-cap 3100Hz
ccm-manager music-on-hold
dial-peer cor custom
dial-peer voice 10 pots
destination-pattern 0.T
incoming called-number .
direct-inward-dial
port 0/0
num-exp 29423473. 73.
num-exp 29423379. 79.
num-exp 29423426. 26.
telephony-service
load 7960-7940 P00307020200
max-ephones 30
max-dn 100
ip source-address 192.168.254.252 port 2000
auto assign 1 to 10
calling-number local
timeouts interdigit 3
time-format 24
date-format dd-mm-yy
create cnf-files version-stamp 7960 Apr 01 2009 03:38:08
max-conferences 4 gain -6
call-forward pattern .T
web admin system name ccmadministrator password c1sc0
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
login timeout 10 clear 01:10
ephone-dn 1
number 101
name 101
translation-profile outgoing 111
ephone-dn 2
number 102
name 102
ephone-dn 3
number 103
name 103
ephone-dn 4
number 104
name 104
ephone-dn 5
number 794
name 105
call-forward all 00622222222
ephone-dn 6
number 106
name 106
ephone-dn 7
number 107
name 107
ephone-dn 8
number 108
ephone-dn 9
number 109
name 109
ephone-dn 10
number 737
name 737
call-forward all 00650271110
ephone-dn 11
number 262
name 262
ephone-dn 12
ephone-dn 98 dual-line
number 100
huntstop channel
no huntstop
ephone-dn 99 dual-line
number 100
preference 1
huntstop channel
ephone 1
mac-address 000D.28D7.6D2C
type 7940
button 1o1,98,99
ephone 2
mac-address 000D.28F3.58D0
type 7940
button 1o2,98,99
ephone 3
mac-address 000C.85BE.6388
type 7940
button 1o3,98,99
ephone 4
mac-address 000C.8546.561B
type 7940
button 1o4,98,99
ephone 5
mac-address 000D.28D7.56E4
type 7940
button 1:5
ephone 6
mac-address 000D.28D7.6D2B
type 7940
button 1o6,98,99
ephone 7
mac-address 000D.28F3.5C4C
type 7940
button 1o7,98,99
ephone 8
mac-address 000D.28D7.6D23
type 7940
button 1o98,99
ephone 9
mac-address 0008.E31B.840E
type 7940
button 1o9,98,99
ephone 10
mac-address 000D.28F3.5932
type 7940
button 1:10
ephone 11
mac-address 0018.1924.2CD0
type ata
button 1:11
ephone 12
mac-address 1819.242C.D001
type ata
button 1:8
You configuration is a bit messed up, unreferenced voice-translation rule, mixed with deprecated translation-rules, etc.
In general, apply translation-rule on the voice-port or trunk-group only, so you don't need them on a bunch of DPs and ephone-dn.
However, post output of "debug isdn q931" for the failed forwarded call. Do not enable any other debug. Most likely, the problem is with numbering type/plan, that being copied from the incoming call, becomes incorrect.
Sorry for the mess. I have been trying too much on this router and should indeed clean up.
My mobile calling the landline (incoming): 622208999
The main number at the office: 294233794
The external destination: 00523620666
The debug:
Jul 1 19:51:46.668: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0, TEI 0 changed to down
Jul 1 19:51:46.672: ISDN BR0/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Jul 1 19:51:49.028: ISDN BR0/0 Q931: RX <- SETUP pd = 8 callref = 0x06
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Calling Party Number i = 0x2183, '622208999'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '294233794'
Jul 1 19:51:49.084: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0, TEI 0 changed to up
Jul 1 19:51:49.092: ISDN BR0/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Calling num 00622208999
Jul 1 19:51:49.104: ISDN BR0/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Called num 0523620666
Jul 1 19:51:49.104: ISDN BR0/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x86
Channel ID i = 0x89
Jul 1 19:51:49.124: ISDN BR0/0 Q931: TX -> SETUP pd = 8 callref = 0x59
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Channel ID i = 0x82
Calling Party Number i = 0x2183, '00622208999'
Called Party Number i = 0xA1, '0523620666'
Sending Complete
Jul 1 19:51:49.316: ISDN BR0/0 Q931: RX <- STATUS pd = 8 callref = 0xD9
Call State i = 0x01
Jul 1 19:51:49.404: ISDN BR0/0 Q931: RX <- CALL_PROC pd = 8 callref = 0xD9
Channel ID i = 0x8A
Jul 1 19:51:50.492: ISDN BR0/0 Q931: RX <- PROGRESS pd = 8 callref = 0xD9
Progress Ind i = 0x8282 - Destination address is non-ISDN
Jul 1 19:51:50.516: ISDN BR0/0 Q931: TX -> PROGRESS pd = 8 callref = 0x86
Jul 1 19:51:54.644: ISDN BR0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0xD9
Cause i = 0x8290 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
Jul 1 19:52:16.452: ISDN BR0/0 Q931: RX <- RELEASE pd = 8 callref = 0x06
Cause i = 0x84EF - Protocol error; unspecified
Jul 1 19:52:16.460: ISDN BR0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x86
Jul 1 19:52:16.496: ISDN BR0/0 Q931: TX -> RELEASE pd = 8 callref = 0x59
Jul 1 19:52:16.564: ISDN BR0/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xD9
Would you also normally use separate dial peers for incoming and outgoing calls? If I'd define a separate dial peer for incoming calls, could I delete the num-exp commands?
However, try
interface bri 0/0
It works! Really appreciated your help. I will now start cleaning up the config first. In your opinion, do I need the rules 110 and 111?
Regarding the isdn tei-negotiation preserve part, we do have the problem (in The Netherlands and Belgium) that the Telco does energy saving, for which I was advised to use tei-negotiation first-call. Would that pose a problem?
You use rules only when something doesn't work or numbers do not show up right. For example, add 00 to international calls as in translation-rule you have.
ISDN BRI disactivate layer 1 in all the world except north america. In your case tei negotiation doesn't apply as you have static tei. Go ahead, enable second BRI in a trunk-group, and remove 0 for external calls, your user will like that, as they will be able to dial just like being home.
Please remember to rate useful posts with the scrollbox below.
Thanks, 2nd BRI is not present, so it's just the 2 voice ports. I'll clean up the rest.
edit: oh crap, you got me there ;)
1 voice-port for BRI, even if it supports two calls :)
Thanks for the nice rating and good luck.
1939
