CME FXO to Centrex long distance code problem
I have a UC520/CME connected to a Centrex switch. With the previous PBX and with a but-set if you dial a long distance number, 9-1-234-564-7890, the Centrex swtich sends back a "tone" that indicates the user needs to then enter an access code. User enters the access code and the call is completed.
Problem: With the UC520 connected, the user is not hearing the "tone" and is not able to enter the access code, therefore long distance calls fail.
Any ideas?
Thanks.
Re: CME FXO to Centrex long distance code problem
lets say ur fxo port 0/0/1
u need to have somthing like:
dial-peer voice 9 pots
destination-pattren 91..........
dtmf-relay h245-alphanumeric
port 0/0/1
forward-digits all
or forward-digits [number of digits u wanna send out of ur fxo]
good luck
if helpful Rate
The dial-peers were matching as the calls would get the PBX, but just wouldn't complete a long distance call due to no access.
Strangely enough the problem seems to have resolved itself.
Thanks for the reply.
350
