CME gives a fast busy tone to all Users!
Greetings,
Recently I configured CME with two fxo ports and everything was working fine untill yesterday when no user is able to dial out!
I have posted the config, how i left it on the day of commissioning.
My second issue, not major at a moment is, I cannot access the unity epress module via http to finish up the voice mail configs. Its keeps telling me login invailed but the acl logs on permitted traffic keep counting whenever i do this. its the same config here.
Any Ideas on what the problem would be?
the dial-peers for the second
the dial-peers for the second fxo are also configured though not reflected in this config!
Silver
When everything was working -
When everything was working - does disconnecting calls was working fine? Did you test that?
For CUE - you have defined ACL 50 for http access...I don't see that ACL in config.
BR,
Dragan
HTH, Dragan
I tested that and everything
I tested that and everything was working fine!
About the acl, its not reflected in the config but its there permiting the 172. users (LAN users).
Silver
And what is the status now -
And what is the status now - how are FXO lines working?
BR,
Dragan
HTH, Dragan
Sure they are, they can
Sure they are, they can recieve incoming calls on both lines.!
Silver
But you still can't send
But you still can't send outgoing calls right?
BR,
Dragan
HTH, Dragan
Right!!!!
Right!!!!
Silver
Well if everything was
Well if everything was working fine, as you said, and now it's not working for outside calls - what changed in recent past?
Something must changed...what "debug voice ccapi inout" tells you?
BR,
Dragan
HTH, Dragan
111
