CME graphical user interface
Hello
What is the minimum IOS required and GUI file to run CME on a 2801 Router.
Flash is 64MB.  Is there any other pre-requisite.
ST
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME graphical user interface
Recommend CME 7.1 minmum, any IOS version.
As indicated above, most memory work fine.
Please remember to rate useful posts clicking on the stars below.
Why do you want minimum IOS. The lower, the less features. Not a good idea.
Hello
I do agree what you mean, but on 2801 Flash is 64MB only and loading IOS supporting Voice and full-GUI.tar will not work. ( out of space )
So I was looking for recommendation.
Can you suggest.
Actually if fits in 64 MB no problem.
Or buy a $10 flash or USB stick. Most do work.
thanks for caring and replying.
Which IOS and GUI file you recommend for 64MB Flash to run CME.
which brand you recommend for external USB, supporting 2801. i am sure are you have experienced on this?
Thanks Sir
Want to see you on 1st place in the forum.
Thank you for the nice rating and good luck!
261
