02-17-2007 04:53 AM - edited 03-14-2019 08:04 PM
I have a CallManager Express 4.0, I had opened in GUI but I am unable to add the phones. I had downloaded the lates basic files for GUI (cme-basic-4.0.0.1[1]) and GUI Files.
But when I added IP Phone in Router I am able to modify the same in GUI.
Is there any limitation in CME for adding IP Phones.
Please help.
Thanks/Regards
karuna
02-17-2007 05:21 AM
make sure you have "auto-reg-ephone" configured. This way the GUI will recognize new phones.
Please rate useful posts.
02-17-2007 11:13 AM
Also make sure the phone is connected.
02-17-2007 10:53 PM
Hi Karuna,
Just to add a note to Paolo and Amit's good info. Here is an excellent thread (including Bug#) that explains this situation;
Hope this helps!Thanks to Jorge from Cisco!
Rob
02-18-2007 08:37 PM
Thanks a lot for your kind help...
Is there any way to assign Partition and CSS in GUI for Phones.
Thanks in advance.
Karuna
02-19-2007 04:17 AM
Karuna, you may be in confusion. CallManager Express don't use CSS and Partions, all the phones are treated equally, and if you want to special things with some of them, there are other means.
02-19-2007 05:48 AM
Karuna,
I think you can use the CORlist options for your Partition and CSS req.
Kumar
02-19-2007 08:33 PM
Is there any way of doing the same in GUI.
Karuna
02-20-2007 03:46 AM
Only the latest 12.4-11XJ1 / CME 4.1 has support for assigning COR to a DN using the GUI. However, you still have to configure the COR list in CLI. In general the GUI is so limited that most task are better executed from CLI.
Please remember to rate useful posts.
