Community Member
CME gui CDR Reports
When all phone are SCCP, there is no problem, I can see CDR from CME 4.2 GUI
When analog FXS phones involved
I see meaningless output from GUI
Here is CDR output from CLI
telelephones #201 , #205 are ip phones
#301 is analog fxs port
#sh call hist vo com
<callID> A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp> disc-cause
1 ANS T1 g729r8 TELE P205 D10
2 ORG T1 g729r8 TELE P201 D10
3 ANS T2 g729r8 TELE P201 D10
4 ORG T2 g729r8 TELE P205 D10
5 ANS T2 g729r8 TELE P301 D10
6 ORG T2 g729r8 TELE P201 D10
7 ORG T2 g729r8 VOIP P 10.1.1.11:21798 D10
8 ANS T2 g729r8 TELE P D10
THANKS
Hall of Fame Super Gold
Re: CME gui CDR Reports
You may want to configure the FXS ports in SCCP mode and that should gave you the same results as for an IP phone.
Note, it seems you're using G728, that is unnecessary on a LAN, and produces less quality audio than G.711u.
Community Member
My configuration is already SCCP
stcapp ccm-group 1
stcapp
stcapp feature access-code
voice-port 0/0/0
timeouts ringing infinity
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
caller-id enable
dial-peer voice 1 pots
preference 7
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
ephone-dn 5 dual-line
number 301
label 301
description 301
name 301
ephone-dn 6 dual-line
number 302
label 302
description 302
name 302
ephone-dn 7 dual-line
number 303
label 303
description 303
name 303
ephone-dn 8 dual-line
number 304
label 304
description 304
name 304
ephone 1
device-security-mode none
mac-address E131.4CF4.0001
ephone-template 1
type anl
button 1:6
ephone 2
mac-address E131.4CF4.0002
ephone-template 1
type anl
button 1:7
ephone 3
mac-address E131.4CF4.0003
ephone-template 1
type anl
button 1:5
ephone 4
mac-address E131.4CF4.0000
ephone-template 1
type anl
button 1:8
330
