Bronze
CME GUI file missing?
Hi, iam trying to setup the cme gui and have downloaded the ios and the correct gui files.However there seems to be missing the ccme.html file.I have checked a few other versions and it is missing from those aswell.
Is this right as i'm sure i've done this before and had the right file in the tar file.
cheers
mark
Hall of Fame Super Gold
Re: CME GUI file missing?
This file doesn't exist and is not needed. it is just part of the URL you enter to access the GUI.
If you have copied the files into a directory, include it with "ip http path ..."
Hope this helps, please rate post if it does
I have the same problem with a 2821 I'm running CME ver 3.3 with IOS 124-3h. I've downloaded and archived the following cme-gui-3.3.0.3a.tar file.
I have, ip http path flash:
Still I don't see ccme.html in the sh flash:
The router comes with http Configuration Manager which works is this my problem?
As I mentioned before:
Yes but when I enter this URL in to my browser I don't get any CME GUI pages that load. I just get page can't be displayed.
So still have a problem getting the GUI working
I appologies a reboot after the achive did the trick and ccme.html did work
726
