CME GUI files
I try to access to CME GUI "http://IP_Address/ccme.html" after I login by username and password it shows nothing blank page. I think there is no files for CME GUI on flash. I have attach show version, dir flash:, show telephony-service.
thank you
1 ACCEPTED SOLUTION
Super Bronze
Re: CME GUI files
The actually call processing part of CME is built into the IOS.
The GUI is downloaded separately, just be sure that you download the correct version for your version of IOS.. check what you have against this sheet, then get the GUI files from the download pages (www.cisco.com/go/software)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Re: CME GUI files
Aaron
Re: CME GUI files
Checking the information that uploaded, I dont see the GUI files in the flash, so what you need to do is download the proper GUI files for you CME and upload those to the routers flash.
After that you need to indicate to the router where to look for those files using the "ip http server" and "ip http path" comand and that should be it.
This link explains how to enable this:
https://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmegui.html
And this one explains how to access it and use it:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/gui/user/guide/cmegui_user.pdf
Walter Solano
CCNA Voice
Cisco UCCX Specialist
412
