07-01-2010 01:51 AM - edited 03-15-2019 11:30 PM
Hi All,
One of my client requested a CME with unity express for below mentioned requirement.
- 100 ip phones to be installed in 8 branches.
- All these branches are connected by MPLS.
- He wants to have voice Mailbox for 100 users with Auto attendant.
However he does not have plan to connect CME with PSTN network and effectively
he wants to use CME only for Onn-net calls (between offices over the mpls link).
so far so good , but he also wants CME's HA ( 2 cme routers) .
My questions are pertaining to CME redundancy.
- Can i provide call processing failover , for instance if primary CME down then Secondary
CME will takeover the registration of ip phones ?
- I am convinced with the fact that i don;t require SRST on primary/secondary CME.
As both the routers would not be connected to pstn network ?
- Can i provide voice mail failover and Auto attendant failover also with 2 CME's?
- If we create HA between two CME do we have to buy 100 user license for both CME?
regards,mangesh
07-01-2010 06:08 AM
CME does support HA by haveing 2 of the same routers and using HSRP between the routers. This will require you to make sure both routers have the exact same configuration.Any changes made on one must be made on the other. You will need to buy and licencse cme for both boxes.
There is no HA for CUE. i would recommend using Unity Connection at one site in HA and then you can put ISM modules with unity survivability at every site to Archie what you are looking to do.
you could have a CUE on the backup CME and just have you AA setup but you cant have any voicemailboxes on there. If the HSRP fails over for any reson you phones will work but your voicemail for users wont.
bottom line is CUCM is a better fit for you with SRST routers.
07-02-2010 12:14 AM
thanks . that explains. just concluding with my present configuration
i cannot provide unity failover. but i can provide call processing failover
and AA failover.
07-02-2010 12:42 AM
Correct.
All HA on CME is not soo clean
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bcs/testcase/reference/guide/whitefnc.html
Title | Description | Expected Results | Comments |
