CME High CPU with 3911 SIP Phone
I have CME 7.0 and 3911 sip phone. The CME's CPU is High because of the process below and CME stop working, then i have to reload do CME to it come back working again.
261     7997344   3286707       2433 59.04% 60.62% 60.68%   0 CCSIP_SPI_CONTRO
263     4128244   3351223       1231 23.53% 24.71% 24.76%   0 CCSIP_UDP_SOCKET
I've already update the IOS to least release available at Cisco web site, but the issue wasn't solved.
c2800nm-spservicesk9-mz.124-24.T4.bin
Does anyboby know something about it ?
Re: CME High CPU with 3911 SIP Phone
Hi Evandro - Tough to say without show run or any information. Please make sure that IP CEF and IP routing is enabled in show run. Check as well for any tracebacks. During high CPU, please collect debug ccsip messages or debug ccsip all. We have to be careful when enabling the debugs so we do not cause the router to hung.
Please log the debugs in the router buffer. Disable logging monitor and logging console. Make sure that the router buffer size is set to 10000000. That should be able to tell you what kind of SIP messages migt be causing such high CPU
Hi Adel,
Thank you for your answear !
Follow in attached the SHOW TECH a Crashinfo file that was created when the problem happened.
I think that it is a Bug, but i haven't found anything on Cisco Web Site about it.
413
