Community Member
cme how increse maximum participants
When i try initiate conference with 3 or 4 paricipants, third and fourth participants listen silent if sccp phone or listen music if sip phone
#show dspfarm all
SLOT   DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0      1   35.1.2   UP     N/A  FREE  conf    1      -         -         -
I think if  i increase maximum participants in conference profile this solve my problem
When i try change  profile i have message  profile oper state is up in progress already
#dspfarm profile 1 conference
(config-dspfarm-profile)#maximum conference-participants 8
(config-dspfarm-profile)#no shutdown
How can i change participants in profile?
Thanks for help
1 ACCEPTED SOLUTION
Hi,You need to do "no
You need to do "no sdspfarm tag 1 confdsp1"
and
"sdspfarm tag 1 confprof1"
Then do "no sccp" followed by "sccp"
Manish
I do not see you shutting
I do not see you shutting down the dspfarm profile , shutdown the dspfarm profile first, make changes and do a no shut.
Manish
Community Member
I perform#dspfarm profile 1
Thanks for your answer
I perform
(config-dspfarm-profile)#shutdown
Disabling profile will disconnect active CONFERENCING calls,
do you want to continue ? [yes/no]yes
(config-dspfarm-profile)#end
#show dspfarm all
Dspfarm Profile Configuration
 Profile ID = 1, Service = CONFERENCING, Resource ID = 1
 Profile Description :
 Profile Service Mode : Non Secure
 Profile Admin State : UP
 Profile Operation State : RESOURCE ALLOCATED
 Application : SCCP   Status : ASSOCIATION IN PROGRESS
 Resource Provider : FLEX_DSPRM   Status : UP
 Number of Resource Configured : 2
 Number of Resources Out of Service : 0
 Maximum conference participants : 8
 Codec Configuration: num_of_codecs:6
 Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
 Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
 Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
 Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Total number of DSPFARM DSP channel(s) 2
I want use conference with three and four participants simultaneously
But problem still exist (
Can you share the 'show run'
Can you share the 'show run' and 'show sccp' from the CME. Also 'show sccp conn' for an active conference call.
Manish
Community Member
Current config in attach
Community Member
i try initiate call between
i try initiate call between to Cisco 6921 IP phones
but command #show sccp connections shows me
Total number of active session(s) 0, and connection(s) 0
Community Member
When conference active
When conference active between three Cisco 6921 IP phones
#show sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
        IPv4 Address: IP
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: IP, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 100
                Trustpoint: N/A
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: IP, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 16, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
In your config, you have
 associate profile 1 register confprof1
and
Change the "sdspfarm tag 1 confdsp1" to  "sdspfarm tag 1 confprof1" and do a no sccp / sccp
Let us know if that fixes the issue.
Manish
Community Member
sorry i newbie in ciscome
me need perform:
#telephony-service
#no sccp
#sdspfarm tag 1 confprof1
#sccp
#end
I understand you correctly?
and
Manish
Community Member
Thank you very much!You
You helped me a lot!!!!!
Conference are now working!
I think this is solved in most settings conference station
That's good to know. Please
That's good to know. Please remember to rate all helpful posts and mark the discussion as solved if your query / issue has been answered / fixed.
Manish
154
