11-01-2008 11:30 PM - edited 03-15-2019 02:18 PM
cme have the four fxo and AA,when the external calls come in,and dial 9+ pstn num,it can call from external call to another external call,how can blocking?
11-02-2008 12:08 AM
Which AA you are using , CUE or TCL ???
Najeeb
11-02-2008 12:15 AM
hi,Najeeb:
AA is using its-CISCO.2.0.2.0.tcl.not the CUE.
thks.
11-02-2008 12:33 AM
try to use this command
#call application voice aa max-extension-length 5
This option declares the maximum length of the extension that the user can dial when dial-by-extension-option is chosen. The default value is 5. The value can be 0 with no restriction up to x digits.
or try
3.
Configure Class of Restriction (COR) to block call transfers from B-ACD to PSTN numbers. The sample configuration below prevents the B-ACD from transferring calls out to local and long distance PSTN numbers. The B-ACD can still transfer calls to internal extensions.
Below is an example of such a configuration:
dial-peer cor custom
name longdistance
name local
dial-peer cor list call-longdistance
member longdistance
dial-peer cor list call-local
member local
dial-peer cor list block-pstn
dial-peer voice 1 voip
corlist incoming block-pstn
application aa
destination-pattern 1000
session target ipv4:192.168.1.1
incoming called-number 1000
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2 pots
corlist outgoing call-longdistance
destination-pattern 91..........
port 0/2/0
dial-peer voice 3 pots
corlist outgoing call-local
destination-pattern 9[2-9]......
port 0/2/0
Najeeb
11-02-2008 01:53 AM
Hi, Najeeb:
it seems use on B-ACD AA TCL,but I is using
its-CISCO.2.0.2.0.tcl.max-extension-length has no effect to its-CISCO.2.0.2.0.tcl.
11-02-2008 03:00 AM
i try the max-extension-length and COR,it doesn't work,the AA still can tranfer to PSTN numbers
name longdistance
name local
member longdistance
member local
dial-peer voice 10 pots
translation-profile outgoing telcom
service aa
destination-pattern 9.T
port 0/1/0
dial-peer voice 11 pots
service aa
port 0/1/1
dial-peer voice 12 pots
service aa
port 0/1/2
dial-peer voice 300 voip
service aa
destination-pattern 51190000
session target ipv4:10.1.3.254
incoming called-number 51190000
codec g711ulaw
no vad
11-02-2008 03:03 AM
Can u please reply me the running config and the tcl script.
11-02-2008 03:26 AM
11-10-2008 06:05 PM
hi,mohdnajeebï¼
do you have any other idea? thank you very much.
11-14-2008 05:19 AM
hi,
i am having same issue with my telephony setup, I will apply your provided command/COR configs and let you know if its works...
Anees Anjum
11-16-2008 05:21 PM
Hi,Anees:
did you have test the command/COR?what is the result?
11-02-2008 01:00 AM
name longdistance <
name local <
11-02-2008 01:18 AM
cme-test(config-app)# service aa
cme-test(config-app-param)#param max-extension-length 5
Warning: parameter max-extension-length has not been registered under aa namespace
06-15-2011 05:16 AM
hi guogiang,
wishing u r fine
I have the same problem now, did u find the solution for this issue?
thanks
06-15-2011 05:34 AM
Hi All, sorry for the late response;
I had applied following configs and they worked fine for me, please try these and let me know if they work. p.s configurations might vary depeneding on your deployment scenario!
name On-Net
name Off-Net
dial-peer cor list Call-On-Net
member On-Net
dial-peer cor list Call-Off-Net
member Off-Net
dial-peer cor list Call-Both
member On-Net
member Off-Net
dial-peer voice 200 pots
corlist outgoing Call-Both
port 0/0/0:XX
dial-peer voice 201 pots
corlist incoming Call-On-Net
service aa
incoming called-number XXX
port 0/0/0:XX
