Community Member
CME, how to change the caller id in the middle?
I have integratoin between CME 4.0(2) and Unity 4.2(1) and want to change the caller id in the middle to create a call handler in Unity box to handle the call CFB/CFN from the ephone.
-DN1000 should able to direct access her personal voice mail (caller id=1000)
-CFN/CFB from DN1000 should kick the call handler which configured extension2000 (caller id=2000)
It works if I apply the profile 'VM' to 'ephone-dn 300' but doesn't in 'ephone-dn 200'
How can I manipulate the caller id to '2000' in 'ephone-dn 200'?
voice translation-rule 1
rule 1 /^1000/ /2000/
voice translation-profile VM
translate redirect-called 1
ephone-dn 100
number 1000
call-forward busy 1400
call-forward noan 1400 timeout 12
ephone-dn 200
number 2000
call-forward all 3000
ephone-dn 300 (VM port for Unity SCCP integration)
number 3000
Thanks in advance,
1 REPLY
Community Member
Re: CME, how to change the caller id in the middle?
Did you try changing the name parameter under ephone-dn?
376
