Community Member
CME - how to create the same abbreviated number for all the users
hi, i need to create some abbreviated numbers in a CME 7.0, so i was thinking to make some translation rules, example 456 - will make a call to a cell phone XXX_XXXXXX, but i have a problem, i am using cor list for the outbounds calls, and these translations rule work with the extension privilegies, so an extension that has only local calls, can not use and abbreviated number pointing to a cell phone. Is there any way to do this? the abbreviated numbers should work for all the users.
thanks
1 ACCEPTED SOLUTION
VIP Purple
Re: CME - how to create the same abbreviated number for all the
One option is to have specific dial peers for these numbers with a less restrictive COR list. Calls will match the more specific dial peer.
Hope this helps.
Brandon
VIP Purple
Hope this helps.
Brandon
Hall of Fame Super Gold
As Brandon said, when you have COR blocking but still want to permit certain numbers, the most practical option is specific DPs.
Then for abbreviated numbers, just create ephone-dn with CFA to the number you want.
120
