CME hunt group loop
I have CME 7.0 and a hunt group with two members in the list
Is the a way to make the group keep cycling so that it is always ringing....dont want call to get to voicemail...
thanks
Colum
VIP Super Bronze
Re: CME hunt group loop
Give this a go..
ephone-hunt 1
pilot 5000
list 1000, 1001, 1003
final 5000
That way after the first 3 numbers ring, then it should go back to the hunt-pilot
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Just a friendly FYI.. With CME 7.0 you can do call blast out of the box. This way all phones in the list ring at the same time. As long as you do not specify a timeout value the call should keep ringing the hunt group.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1145800
I would not take no value in the timeout
thanks for the info on the callblast
It would not allow me to point the final to the hunt list
thanks
Then create a ephone_DN that forwards back to the huntlist..
VIP Super Bronze
Just Like Kevin said, do the following:
ephone-dn xxxx
CFA 5000 (whatever your hunt pilot number is)
then configure your hunt list final to point to ephone-dn xxxx
630
