cme imap integration
Hi folks,
Im looking for a config exemple of how setup the cue 3.1 to support imap.
tks.
Re: cme imap integration
I believe the answer to your question is laid out in the following configuration guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/administrator/voicemail/12advVM.html#wpmkr1025284
Configuring Integrated Messaging
Follow this procedure to configure the Integrated Messaging capability.
Prerequisites
The system must have a default security certificate and private key  installed before SSL connections are permitted on Cisco Unity Express.  Use the show crypto key command to display  the system default certificate-key pair. If no default pair exists,  follow the procedure in "Configuring Security"  on page 295.
Required Data for This Procedure
Name of a subscriber group that has the vm-imap privilege.
SUMMARY STEPS
1. config t
2. service imap
3. enable
4. maxsessions num-sessions
5. session idletimeout minutes
6. session security {ssl | none | mixed | keyLabel labelname}
7. enable
8. no enable
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hello William,
tks for the answer,
im looking for a sh run sample config. Also if you have a screen shoot in outlook how to setup the mail accompt.
tks all
533
