CME in SRST Mode with h.323 CUCM - wrong dial-peer matching
Hi All,
I have a question about cme in SRST mode:
We have configured SRST mode with "auto provision all" and SRST works fine.
But when the WAN comes back, the router is still using the cme dial peers instead of the VoIP dial-peer to CUCM (h.323).
I thought that the SRST config will avoid this behavior.
What we have done is giving a lower preference to the lines, but I'm not sure if this is the right way.
I played with different dial-peer hunt commands as well, but I think none will fit the requirement.
Can anyone give me a hint ?
Steffen
1 REPLY
Hi Steffen,
When you use the auto provision all command it writes the ephones that register to the actual running config.  Try using auto provision none instead, and/or manually configure the ephones/ephone-dn's and assign preferences to make sure correct dial-peers are being matched.
HTH,
Chris
301
