Community Member
CME inbound SIP calls not ringing
hello, I can call outbound fine from my CME to my ITSP via SIP, however incoming calls are not ringing on any of my phones.
Any help here would be great. I am sure it is a simple thing I am missing,
here is my config:
Thanks kindly for any help.
Current configuration : 5981 bytes
version 15.1
hostname 2801Router
boot-start-marker
boot system flash:c2801-ipvoicek9-mz.151-2.T0a.bin
boot-end-marker
aaa new-model
aaa session-id common
clock timezone nzst 13 0
dot11 syslog
ip source-route
ip dhcp pool DATA_SCOPE
   network 192.168.200.0 255.255.255.0
   default-router 192.168.200.1
   dns-server 8.8.8.8
ip dhcp pool VOICE_SCOPE
   network 192.168.100.0 255.255.255.0
   default-router 192.168.100.1
   option 150 ip 192.168.2.115
ip cef
ip domain name demo.net
ip name-server 4.2.2.2
no ipv6 cef
voice class codec 1
codec preference 1 g711alaw
voice translation-rule 1
rule 1 /^9/ //
voice translation-profile Strip9ToGetOut
translate called 1
voice-card 0
crypto pki trustpoint TP-self-signed-2995340181
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2995340181
revocation-check none
crypto pki certificate chain TP-self-signed-2995340181
certificate self-signed 01
  3082024B 308201B4 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393935 33343031 3831301E 170D3733 30393038 31363435
  30345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 39393533
  34303138 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C34D C8ECBB53 E01373A3 2E286B78 2D23042B 1C8588B1 A7861899 BA1C6860
  AE1D7868 2A59E3BC 54D0A457 8FFDE27F C09104E5 C7A429F3 74CD9DA8 4A980366
  675CC27C CDB94838 821CC05F 2C0AC2BC D882C132 6CAA1FA6 6DA740E4 562428B1
  12B741F1 A50C9246 4CC35EDA DEE1D038 3883BB35 A91ABF8B 483E4160 F5FA4B5A
  9A570203 010001A3 73307130 0F060355 1D130101 FF040530 030101FF 301E0603
  551D1104 17301582 13323830 31526F75 7465722E 64656D6F 2E6E6574 301F0603
  551D2304 18301680 14721196 40F3396E 1FE41680 86D31D86 190D8337 FF301D06
  03551D0E 04160414 72119640 F3396E1F E4168086 D31D8619 0D8337FF 300D0609
  2A864886 F70D0101 04050003 818100AF E92F8BC4 19F5E0AB B4718F19 0D86B9CC
  74FB352A 55AD288F 0A0BE12F 3E0D43D2 1B52A07A 466BDD33 9041BCAB 96A99FED
  5E3AC098 D29BC1BD 646D16E4 BAE341EC DA7A5323 0F5B34D9 086B31DA CC770A83
  A4A1D333 519982BA AD8A326C 268B3B93 AE75284F ABE1BE0F 2E488858 0E2D140A
  075FE477 E1C9C006 FEA3945D 617CAE
        quit
license udi pid CISCO2801 sn FTX0947W07M
username phil privilege 15 password 0 phil
username admin privilege 15 secret 5 $1$eyWi$122pB8ItNv2vy9akYpAdP.
interface FastEthernet0/0
ip address 192.168.3.50 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/1.99
encapsulation dot1Q 99
ip address 192.168.99.1 255.255.255.0
interface FastEthernet0/1.100
description voice_VLAN
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
interface FastEthernet0/1.200
description data_VLAN
encapsulation dot1Q 200
ip address 192.168.200.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source static tcp 192.168.2.115 8443 interface FastEthernet0/0 8443
ip route 0.0.0.0 0.0.0.0 192.168.3.1
logging esm config
tftp-server flash:/phone/7940-7960/P00307020200.bin alias P00307020200.bin
tftp-server flash:/phone/7940-7960/P00307020200.loads alias P00307020200.loads
tftp-server flash:/phone/7940-7960/P00307020200.sb2 alias P00307020200.sb2
tftp-server flash:/phone/7940-7960/P00307020200.sbn alias P00307020200.sbn
control-plane
mgcp fax t38 ecm
dial-peer voice 1 voip
description local_7_Digit_Calling
translation-profile outgoing Strip9ToGetOut
destination-pattern 9[2-9]......
session protocol sipv2
session target ipv4:203.184.16.2
voice-class codec 1
dial-peer voice 2 voip
description international_calling
destination-pattern 900T
voice-class codec 1
dial-peer voice 3 voip
description national_calling
destination-pattern 90[34679].......
voice-class codec 1
sip-ua
authentication username 6494785678 password 7 08127F590C1D0D00135258
calling-info pstn-to-sip from number set 6494785678
registrar dns:akl.italk.co.nz:5060 expires 180
sip-server ipv4:203.184.16.2:5060
telephony-service
max-ephones 10
max-dn 20
ip source-address 192.168.100.1 port 2000
load 7960-7940 P00307020200
max-conferences 4 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Jul 28 2013 18:13:57
ephone-dn  1
number 6494785678
ephone  1
mac-address 000C.8546.5954
button  1:1
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
scheduler allocate 20000 1000
ntp server 195.43.74.123
end
2 ACCEPTED SOLUTIONS
Silver
your calls are failing due to the toll fraud feature. Try disabling it completely or add the provider's ip address as a trusted host. Here are more details on this feature:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
Posted by WebUser Asad Raza from Cisco Support Community App
Community Member
Re: CME inbound SIP calls not ringing
Fran,
Web User Raza is right see below:
Aug 17 03:09:43.778: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Aug 17 03:09:43.778: //287/4C73A0268070/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Aug  17 03:09:43.778:  //287/4C73A0268070/SIP/Event/Session-Timer/sipSTSLMain: dir:1,  method:102, resp_code:403, container:67BD4268
Aug 17 03:09:43.782: //287/4C73A0268070/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 203.184.16.89:5060;branch=z9hG4bKt6jbm3107or1koo690j0.1
To: <6494785678-SBLHJS71QNMA8>;tag=4BBBBC-14E3
Date: Sat, 17 Aug 2013 03:09:43 GMT
Call-ID: 1f55a6d25e85c7c222d4376b6287e3fb@203.184.16.2
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Reason: Q.850;cause=21
Content-Length: 0
How to Identify if TOLLFRAUD_APP is Blocking Your Call
If the TOLLFRAUD_APP is rejecting the call, it generates a Q.850       disconnect cause value of 21, which represents ‘Call Rejected’.
The call comes from 203.184.16.89 which is not there in the trusted list of router #show ip address trusted list
Add:
voice service voip
     ip v4 0.0.0.0 0.0.0.0
Silver
can you enable 'debug ccsip messages' and capture an incoming call?
Community Member
voice-class codec 1
try adding "incoming called-number 6494785678" under above dial-peer.
And, provide us with the output of "debug ccsip message" and "debug ccsip events"
Community Member
thank you kindly for your help.
I added the "incoming called-number" details under dial-peer voice 1 voip as Nadar suggested and enabled "debug ccsip message" and "debug ccsip events".
Here are the debug results.
Thank you kindly if you can offer any suggestions based on this output:
SIP Call messages tracing is enabled
2801Router#debug ccsip events
SIP Call events tracing is enabled
2801Router#term mon
2801Router#
Aug 17 03:09:43.754: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:6494785678@192.168.3.50:5060 SIP/2.0
Contact:
CSeq: 102 INVITE
User-Agent: italk PBX
Max-Forwards: 69
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Content-Type: application/sdp
Content-Length: 352
v=0
o=root 8421 8421 IN IP4 203.184.16.89
s=session
c=IN IP4 203.184.16.89
t=0 0
m=audio 17376 RTP/AVP 8 18 97 3 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=rtpmap:3 GSM/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Aug 17 03:09:43.762: //287/4C73A0268070/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Aug 17 03:09:43.766: //287/4C73A0268070/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:67BD4108
Aug 17 03:09:43.766: //287/4C73A0268070/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2000
Aug 17 03:09:43.770: //287/4C73A0268070/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
Aug 17 03:09:43.770: //287/4C73A0268070/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:67BD3A28
Aug 17 03:09:43.774: //287/4C73A0268070/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Sent:
CSeq: 102 INVITE
Content-Length: 0
Aug 17 03:09:43.798: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:6494785678@192.168.3.50:5060 SIP/2.0
CSeq: 102 ACK
Max-Forwards: 69
Content-Length: 0
Aug 17 03:09:52.158: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Aug 17 03:09:52.158: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Aug 17 03:09:52.162: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:akl.italk.co.nz:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.50:5060;branch=z9hG4bKCE126B
To: <>1000@akl.italk.co.nz>
Date: Sat, 17 Aug 2013 03:09:52 GMT
Call-ID: 3DFC1198-44BF11B6-8002BD95-9B53C000
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1376708992
CSeq: 43 REGISTER
Contact: <1000>
Expires:  180
Supported: path
Content-Length: 0
Aug 17 03:09:52.170: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Aug 17 03:09:52.174: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.3.50:5060;branch=z9hG4bKCFB6D
To: <>1001@akl.italk.co.nz>
Call-ID: 3E3CC5B2-44BF11B6-8003BD95-9B53C000
Max-Forwards: 70
CSeq: 43 REGISTER
Contact: <1001>
Expires:  180
Supported: path
Content-Length: 0
Aug 17 03:09:52.182: //288/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 192.168.3.50:5060;received=101.98.183.26;branch=z9hG4bKCE126B;rport=59241
To: <>1000@akl.italk.co.nz>;tag=aprqngfrt-i9gu4710000m2
CSeq: 43 REGISTER
Aug 17 03:09:52.194: //289/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.3.50:5060;received=101.98.183.26;branch=z9hG4bKCFB6D;rport=59241
To: <>1001@akl.italk.co.nz>;tag=aprqngfrt-c1e4ki10000m2
CSeq: 43 REGISTER
Aug 17 03:09:52.578: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Aug 17 03:09:52.578: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Aug 17 03:09:52.582: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.3.50:5060;branch=z9hG4bKD0500
To: <>1002@akl.italk.co.nz>
Call-ID: 3E7F4BA7-44BF11B6-8004BD95-9B53C000
Max-Forwards: 70
CSeq: 43 REGISTER
Contact: <1002>
Expires:  180
Supported: path
Content-Length: 0
Aug 17 03:09:52.586: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Aug 17 03:09:52.590: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.3.50:5060;branch=z9hG4bKD11361
To: <>1003@akl.italk.co.nz>
Call-ID: 3ED2EAFA-44BF11B6-8005BD95-9B53C000
Max-Forwards: 70
CSeq: 43 REGISTER
Contact: <1003>
Expires:  180
Supported: path
Content-Length: 0
Aug 17 03:09:52.598: //290/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.3.50:5060;received=101.98.183.26;branch=z9hG4bKD0500;rport=59241
To: <>1002@akl.italk.co.nz>;tag=aprqngfrt-m1e2mc10000m2
CSeq: 43 REGISTER
Aug 17 03:09:52.606: //291/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.3.50:5060;received=101.98.183.26;branch=z9hG4bKD11361;rport=59241
To: <>1003@akl.italk.co.nz>;tag=aprqngfrt-c9j4ln10000m2
CSeq: 43 REGISTER
Aug 17 03:09:59.270: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:6494785678@192.168.3.50:5060 SIP/2.0
Via: SIP/2.0/UDP 203.184.16.89:5060;branch=z9hG4bKe56vhf200071km0ch141.1
Contact:
Call-ID: 052efb0239bf13f311f5fd785992dd6a@203.184.16.2
CSeq: 102 OPTIONS
Max-Forwards: 69
Date: Sat, 17 Aug 2013 03:09:59 GMT
Supported: replaces
Content-Length: 0
Aug 17 03:09:59.278: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_OPTIONS_RESP
Aug 17 03:09:59.282: //292/55B335B08075/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <6494785678-SBLHJS71QNMA8>;tag=4BF844-1FD9
CSeq: 102 OPTIONS
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Accept: application/sdp
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Content-Length: 167
v=0
o=CiscoSystemsSIP-GW-UserAgent 3497 3262 IN IP4 192.168.3.50
s=SIP Call
c=IN IP4 192.168.3.50
t=0 0
m=audio 0 RTP/AVP 18 0 8 9 4 2 15
Community Member
Fran,
Sent:
CSeq: 102 INVITE
Content-Length: 0
Add:
voice service voip
Silver
559
