CME Incoming translation for "Missed Calls" list
I´ve configured the following translation rule set to add a leading "0" to incoming numbers, in order to have a working "Missed Calls" list.
The rules are for Florida (Orlando), but i´m not sure if they are 100% correct.
 voice translation-rule 9
 rule 1 /^321\(.*\)/ /0321\1/
 rule 2 /^407\(.*\)/ /0407\1/
 rule 3 /^1321\(.*\)/ /0321\1/
 rule 4 /^1407\(.*\)/ /0407\1/
 rule 8 /\(1..........\)/ /0\1/
 rule 9 /\(..........\)/ /01\1/
voice translation-profile INCOMING_TRANSLATION
 translate calling 9
 translate called 1
Does anyone have experiences with this here in Florida?
Another question would be: How can  international incoming numbers be identified, so i would add a "0011" as a prefix?
Thanks!
Heinz
Silver
For everything related to
For everything related to translations you have very usefull testing tool inside CME:
test voice translation ... - in "enable" mode
Try it.
HTH,
Dragan
HTH, Dragan
Thanks - I know this test
Thanks - I know this test method. The problem is, that I dont know how calls from external countries (i.e. Canada, Mexico, Germany, ...) can be identified exactly. Is there a strict rule (i.e. the number of digits)?
Thanks!
Silver
Well I think there is no way
Well I think there is no way that you can match international numbers based on number of digits or something like that...there are just to much options for that smiley
HTH,
Dragan
HTH, Dragan
32
