Community Member
CME Install Question
Sorry for the basic question but I am trying to install CME 7.0(1) on an ISR running IOS ver C-2801-IPVOICEK9-M Version 12.4(25) rel fc2. So far I have donwloaded the file "cme-full-7.0.0.1.tar" and extracted it's contents to flash and rebooted after following the readme files instructions. My phones all came up ok but the problem is when I run "show telephony-service" it says I am running cme "Version 3.3" I'm not clear on what else I have to do here? Should it not say Verion 7.01 or similar?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME Install Question
You need to update IOS to the latest T version for CME 7.x
The files in flash are just phone firmware, GUI, etc, are accessories and do not make the real thing - that is IOS.
Community Member
Makes sense... Thanks!
You're welcome, thanks for the appreciation and good luck.
186
