Community Member
CME inter dial not working between remote sites
We have two remote office, Ohio and St. Petes. I cannot get the two offices to interdial each other. We want to dial just 4 digits to between remote locations.
Will the following work:
If i add the following Dial Peer to Florida
dial-peer voice 87 voip
destination-pattern 87.[1-9]<<<<don't know if this setup is correct???
session target ipv4:192.168.
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Is this correct
Also if I dial the following to OHIo, is this correct.
dial-peer voice 8600 voip
preference 1
destination-pattern 86..
session target ipv4:172.17.86.1
codec g711ulaw
no vad
Hall of Fame Super Gold
Re: CME inter dial not working between remote sites
Config appears correct, do the ephone-dn have number like the destination-pattern ?
unrelated to this, if you use trunkgroup for the voice-ports, you will be able to eliminate all the redundant dial-peer that are repeated over and over.
Community Member
we are moving to full blown call maanger shortly. So there will be lots of changes. BUt thanks for the advise.
Unfortunately, with the dial peer setup i have it still is not working. When someone from Ohio calls Florida using the 4 ditigit extensions they are getting a busy signal.
Ohio uses 8700 scheme
Florida uses 8600 scheme
Try adding "session protocol sipv2" to DP and enable "term mon" and "debug ccsip message". This will give you a idea in clear text why the call fails.
Community Member
ok, i added the session protocol sipv2 command.. Here is what my dial peer looks now:
preference 1
no vad
Below is what the debug ccsip message shows. This time we dialed then we got dead silence.
It is attached.
hi,
ohaio is not receiving any reply, check your connectivity (FW, NAT, VPN or whatever you have in between the routers).
Community Member
What did you see in the debug that might have indicated that??
No reply to sip invite is ever received by the router. Either the other router doesn't receive them, or receives but the replies are dropped somewhere.
117
