CME intermitant incoming low volume calls
Hi, I am experiencing intermitant low volume incoming calls on CME 4.1 with a PRI. Especially and mostly when doing a group pickup of another extension. There is no discernable pattern to the quiet calls, from various local, national and international numbers.
Any help appreciated.
Ryan
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CME intermitant incoming low volume calls
Hi, I suggest you upgrade to 12.4(11)XJ4 that is the most stable release with most bugfixes.
For the phones I suggest 8.2(2)SR4 alsto latest stable.
I have this combo on many customers, but admittedly they don'use group pick-up.
Hi, can you send output of "show controllers E1" or T1. you may be getting slips.
Your right on the slips. here is a partial output. Will this be a provider issue?
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20070320, FPGA: 20, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (672 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
542 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
542 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
728 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
728 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 2:
727 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
727 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 3:
No, config issue:
network-clock-participate wic 0
network-clock-select 1 e1 0/0/0
And you will be ok.
Thanks, I will give it a go and see how it gets on. I will have to leave it for a few days for the company to come back to me.
Sure. Remember, ISR routers need network-clock commands. Older models do not.
The commands have resolved the slip issues on the E1 card. However, I am still experiencing intermittant and seemingly random quiet/silent incomming calls when the call is answered via a group pick-up.
Any Ideas?
Which exact IOS are you using, which phone types and firmware on them ?
IOS is spservicesk9-mz.124-15T1 sitting on a 2811 with 64Mb Flash and 256Mb Dynamic Ram.
CUME is 4.1(0)with 2 x 32 PVDM modules.
Phones are 14 x 7941G running SCCP41.8-2-2SR1S all placed in 1 pick-up group.
Direct calls to extensions seem to be fine. The quiet calls are when a group pick-up is done. Also the silence is one way. incoming can't be heard, but out going can be.
598
