CME (ios 15.1) SIP REGISTER doing a REFER back to invoking SIP Client
CME / ios / SIP Experts,
I am trying to get Cisco Unified Call Manager Express (CME) up and running on my 2901 ios router:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(3)T4, RELEASE SOFTWARE (fc1)
I have configured the SIP server and added a couple of SIP phones and am now testing SIP REGISTER via the Blink (Mac OS X) client.
The client is on a private 192.168.x.x network.
The Cisco CME Router is sitting between internet (public IP address) and private 192.168.x.x network.
The Client is configured to send SIP requests to the private network interface on the Cisco CME Router.
The behavior I am seeing from Client SIP log is summarised below:
1. Blink (REGISTER sip:mydomain.com) -> Cisco CME
2. Cisco CME (100 Trying) -> Blink
3. Cisco CME (401 Unauthourized + WW-Authenticate) -> Blink
4. Blink (REGISTER sip:mydomain.com + Authorization) -> CISCO CME
5. Cisco CME (100 Trying) -> Blink
6. Cisco CME (REFER sip:XXXX@192.168.X.130)
    Where the REFER is to actual SIP address of the Blink Mac OS X client
7. Cisco CME (500 Internal Server Error) -> Blink
9.  Repeating :  Cisco CME (REFER sip:XXXX@192.168.X.130)
So the question is:
1. Why is the original REGISTER not successful
2. Why is the CME SIP Registar send the REFER back?
Here is the relavant Subset of the CME/ios of Config:
<Config>
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname toadstool
boot-start-marker
boot system flash0:/c2900-universalk9-mz.SPA.151-3.T4.bin
boot-end-marker
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.10.126 192.168.10.254
ip dhcp excluded-address 200.30.200.1 200.30.200.79
ip dhcp excluded-address 200.30.200.91 200.30.200.126
ip domain name froghop.com
voice-card 0
dsp services dspfarm
voice service voip
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h450.7
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server expires max 600 min 60
voice register global
mode cme
source-address 200.30.200.190 port 5060
max-dn 20
max-pool 35
load 8961 8961/sip8961.9-2-2SR1-9
load 7942 7942-62/SIP42.9-2-1S
authenticate register
authenticate realm froghop.com
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0002689782282013
voice register dn  1
number 72332
call-forward b2bua busy 723851
call-forward b2bua noan 725851 timeout 30
name Joe Toad
label Joe Toad
voice register dn  2
number 611851
call-forward b2bua noan 72332 timeout 20
name LineA Home
label Home Line-A
voice register dn  3
number 72851
label 942 Door
voice register dn  4
number 723851
label Home Line-C
voice register pool  1
id mac 000B.8233.9B86
number 1 dn 2
username XXXX password XXXXX
voice register pool  2
id mac 0000.BEE1.BEE2
number 1 dn 1
username joe password XXXXX
voice translation-rule 5
rule 1 /^001161\(.*\)/ /0\1/
rule 2 /^\+61\(.*\)/ /0\1/
voice translation-profile local
translate called 5
interface Loopback0
ip address 200.30.200.190 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
zone-member security in-zone
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description $ETH-LAN$$FW_INSIDE$
ip address 200.30.200.130 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security PRIVATE-ZONE
duplex auto
speed auto
no mop enabled
interface FastEthernet0/2/0
ip address 192.168.1.160 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
no mop enabled
interface FastEthernet0/2/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
no mop enabled
interface ATM0/3/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0/3/0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface GigabitEthernet0/0/0
interface GigabitEthernet0/0/1
interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/3
interface Virtual-Template1 type serial
description $FW_INSIDE$
ip unnumbered Loopback0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
interface Vlan1
description $ETH-4ESG$$INTF-INFO-10/100/1000 Ethernet$$ETH-LAN$FW-DMZ$$FW_INSIDE$$ES_LAN$
ip address 200.30.200.1 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
zone-member security dmz-zone
interface Dialer0
description $FW_OUTSIDE$
ip address 175.249.76.71 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname XXXXXXXXXXXX@XXXXXXXXXXXXXXXX
ppp chap password 7 101D5A49544442
ppp pap sent-username XXXXXXXXXX@XXXXXXXXXXX password 7 XXXXXXXXXXXXXXXX
service-policy input sdmappfwp2p_CCP_MEDIUM
service-policy output sdmappfwp2p_CCP_MEDIUM
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
control-plane
call threshold global cpu-avg low 68 high 75
call threshold global total-mem low 75 high 85
call threshold global total-calls low 1 high 1
mgcp profile default
dspfarm profile 10 transcode
description G711Transcode
codec g711ulaw
codec g711alaw
maximum sessions 4
associate application SCCP
dspfarm profile 20 transcode
description GenTranscode
codec g729abr8
codec g729ar8
codec g729r8
codec g722-64
codec ilbc
codec g729br8
codec isac
codec gsmamr-nb
codec pass-through
maximum sessions 1
dspfarm profile 30 conference
description Conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec g722-64
codec ilbc
maximum sessions 1
dial-peer voice 1 voip
description PSTN
translation-profile outgoing local
preference 1
session protocol sipv2
session target sip-server
incoming called-number .T
dtmf-relay sip-notify
sip-ua
authentication username xxxxxxxxxxxxxx password 7 xxxxxxxxxxxxxxxxx
timers connect 100
sip-server dns:pots-gw.froghop.com
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-dn 20
ip source-address 200.30.200.190 port 2000
max-redirect 5
cnf-file location flash:
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
web admin system name XXXXXXXxx secret 5 XXXXXXXXXXXXXXXX
dn-webedit
time-webedit
transfer-system full-consult
directory last-name-first
create cnf-files version-stamp 7960 Jun 21 2012 08:27:54
ntp server 171.10.7.211
end
</Config>
With the SIP configuration. I have deliberately not added in any bind commands for the Control and Media interfaces, as the CME ios Router should be acting as gateway between Public & Private interfaces and so should be handling SIP requests on both of these interfaces.
I am not using any Cisco phone and so do not need to support skinny (CSSP) and just want to support generic SIP gateways and phones.
I have not started to work on getting Dial Plans sorted out yet, as if I cannot get a phone to REGISTER, then nothing else will work or is testable.
I have also attached the SIP Log trace from Blink in the attached file.
Thank you for any light you can throw on this.
John.
Everyone's tags (4)
Re: CME (ios 15.1) SIP REGISTER doing a REFER back to invoking S
You have to add SIP binding to work. After adding it, you should reapply create profile command in register global.
Also, you need to enable supplementery service refer in SIP since its required for registration and call transfer.
One more thing, I can see that you are using zone based firewall but you didn't inculde the policies. For precatuions check if its blocking something.
"if you find this post useful, please rate"
Hi Mohammed,
thanks for your suggestions.
Even when I updated the SIP config:
voice service voip
sip
  bind control source-interface Loopback0
mode cme
max-dn 20
max-pool 35
authenticate realm frogdrop.com
time-format 24
date-format D/M/Y
tftp-path flash:
Changes include:
# voice service voip
# supplementary-service sip refer
# sip
# bind control source-interface Loopback0
I am still getting the REFER & 500 Internal Server Error generated, so am unable to register.
Also as I added in the bind, which result in binding to the public facing Loopback0 interface, I had to change the Blink SIP client to do register on this interface (as it could not longer contact the PRIVATE interface on 192.168.X.X network.
To your question about the ZBFW setting, I have configured SIP inspection and can have no problems getting response from the interfaces, as long as I ensure that the Blink SIP Proxy settings are always the same as the "bind control source-interface" setting.
As per my earlier post, I do not realy want to do a "bind control source-interface" as this means that I cannot have a SIP listener on both the public and the private interfaces, which I need for:
1. Allowing general SIP INVITE calls to enter SIP via Public Interface
2. Allow remote users to do SIP REGISTER via Public Interface
3. Allow communications with external SIP provider for international calls
4. Allow my internal SIP users to use the PRIVATE interface to do SIP REGISTER
5. Allow my internal SIP clients to do intra-office calls by directly calling local SIP numbers.
NOTE: that the REFER message has the following contents:
notify_displayMax Phones Exceeded1001
Does the "Max Phones Exceeded" have any significance???
How can I have exceeded by maximum no of phones, when I have not even managed to get a single phone to register?
Thanks for your help.
Regard,
John.
1421
