CME IOS 15 SIP trunk with SPA9000
Dear Sirs,
We are trying to integrate CME ISR G2 with a Linksys SPA9000 IP PBX.
We can place calls from the SPA to a CME phone but not vice versa.
We changed the parameter on the SPA to not register the trunk.
Any other clues why there calls can not be made using a Cisco phone to a linksys one?
Thanks in advance,
Nick
Hall of Fame Super Gold
Take "debug ccsip message" with "term mon". Do not enable other debugs. Do not use attachments.
Dear Paolo,
Below is a debug ccsip all
Jan  9 14:47:22.722: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[2292] removed.
Jan  9 14:47:22.722: //2465/98AFC3AB82C5/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Jan  9 14:47:22.722: //2465/98AFC3AB82C5/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x31853220 key=992F54CA-3A0711E1-82CAEEFB-5980959F@192.168.0.250
Jan  9 14:47:22.722: //2465/98AFC3AB82C5/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Jan  9 14:47:22.722: //2465/98AFC3AB82C5/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Jan  9 14:47:22.722: //2465/98AFC3AB82C5/SIP/Info/ccsip_offer_ans_delete:
Jan  9 14:47:22.722: //2465/98AFC3AB82C5/SIP/Info/ccsip_iwf_delete:
Jan  9 14:47:22.722: //2465/98AFC3AB82C5/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 31853220
Jan  9 14:47:25.010: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x31853220) with key=[2294] to table
Jan  9 14:47:25.010: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
Jan  9 14:47:25.010: //-1/000000000000/SIP/Info/ccsip_iwf_init:
Jan  9 14:47:25.010: //-1/000000000000/SIP/Info/ccsip_ipip_media_service_init:
Jan  9 14:47:25.010: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization:  Entry...
Jan  9 14:47:25.010: //2469/000000000000/SIP/State/sipSPIChangeState: 0x31853220 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/ccsip_iwf_handle_peer_event:
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 1, Event Id: 174
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/ccsip_iwf_process_event:
Jan  9 14:47:25.010: //2469/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_default_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_MODE
Jan  9 14:47:25.010: //2469/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/ccsip_get_int_type_frm_set_mode_ev:
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/is_mode_sip_sip_md:
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/is_mode_sip_sip_ed:
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/is_mode_sip_h32x_in_set_mode:
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/is_mode_sip_h323_in_set_mode:
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/is_mode_sip_sccp_in_set_mode:
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/sip_iwf_def_set_mode_hdlr: Setting SPI mode to SIP-TDM
Jan  9 14:47:25.010: //2469/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_sccp_early_dialog_container
Jan  9 14:47:25.010: //2469/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:CNFSM_NO_STATE_CHANGE
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Jan  9 14:47:25.010: //2469/000000000000/SIP/Info/ccsip_iwf_map_ccapi_event_to_iwf_event: Event Category: 3, Event Id: 5
Jan  9 14:47:25.014: //2469/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SET_FLOW_MODE
Jan  9 14:47:25.014: //2469/000000000000/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Jan  9 14:47:25.014: //2469/000000000000/SIP/Info/is_fa2ft_md_flow_mode_transition:
Jan  9 14:47:25.014: //2469/000000000000/SIP/Info/is_fa2ft_flow_mode_transition:
Jan  9 14:47:25.014: //2469/000000000000/SIP/Info/ccsip_get_flow_mode_frm_set_flow_mode_ev:
Jan  9 14:47:25.014: //2469/000000000000/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Jan  9 14:47:25.014: //2469/000000000000/SIP/Info/ccsip_iwf_handle_peer_event: Return value : SIP_IWF_SUCCESS
Jan  9 14:47:25.014: //2469/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
Jan  9 14:47:25.014: //2469/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
Jan  9 14:47:25.014: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 192.168.0.155 target_port : 5060
Jan  9 14:47:25.014: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [101]
Jan  9 14:47:25.014: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 9A5 to table
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIGetCallConfig: Media forking disabled
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=2468
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIGetModemConfig:
From Config: Modem NSE payload = 100, Passthrough = 4, Modem relay = 0, Gw-Xid = 1
SPRT latency 200, SPRT Retries = 12, Dict Size = 1024
String Len = 32, Compress dir = 3
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/ccsip_iwf_process_event:
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_INIT_CALL_SETUP
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/State/ccsip_cnfsm_debugs: IWF:new_container:sip_iwf_main_container
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/ccsip_iwf_process_event: IWF - cnfsm ret 2
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.0.250
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/resolve_sig_ip_address_to_bind: signaling bind address : 192.168.0.250
Jan  9 14:47:25.014: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 19160 for stream 1
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Jan  9 14:47:25.014: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
Jan  9 14:47:25.014: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Media/sipSPIProcessRtpSessions: No active streams.
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
Jan  9 14:47:25.014: //2469/AD3510ED82D1/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x31853220 key=ADA2EE8A-3A0711E1-82D6EEFB-5980959F@192.168.0.250
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = ADA2EE8A-3A0711E1-82D6EEFB-5980959F@192.168.0.250
Jan  9 14:47:25.018: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 192.168.0.155,Port 5060, Transport 1, SentBy Port 5060
Jan  9 14:47:25.018: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:2C2C2AB0
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/Session-Timer/sipSTSLSRReqSend: Session timer is not required
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/Session-Timer/sipSTSLMain:
    SE: 0;refresher:none peer refresher:none, flags:2000, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
    Configured SE:1800, Configured Min-SE:1800
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/ccsip_offer_ans_handle_sent_sdp:
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/ccsip_offer_ans_process_event:
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_IDLE, event:E_SIP_INVITE_SDP_SENT
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/ccsip_offer_ans_is_invite_offer_valid:  - 1
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/ccsip_offer_ans_common_offer_sent_hdlr:
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/ccsip_iwf_handle_network_event:
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/ccsip_iwf_process_event:
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/State/ccsip_cnfsm_debugs: IWF:cur_container:sip_iwf_sccp_early_dialog_container, cur_state:S_SIP_IWF_SDP_IDLE, event:E_SIP_IWF_EV_SENT_SDP
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/is_sent_sccp_do_video_inactive:
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/is_mode_sip_sccp_do_video:
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/sip_iwf_def_ed_sent_sdp_offer_hdlr:
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/State/ccsip_cnfsm_debugs: IWF:next_state:S_SIP_IWF_SDP_SENT_AWAIT_SDP
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/State/ccsip_cnfsm_debugs: OA:next_state:S_SIP_EARLY_DIALOG_OFFER_SENT
Jan  9 14:47:25.018: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
SIP: (2469) Group (a= group line) attribute, level 65535 instance 1 not found.
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/sipSPISendInvite: Associated container=0x2C2C2AB0 to Invite
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Transport/sipSPITransportSendMessage: msg=0x30A0EC1C, addr=192.168.0.155, port=5060, sentBy_port=0, local_addr=192.168.0.250, is_req=1, transport=1, switch=0, callBack=0x251BAD08
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Jan  9 14:47:25.018: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.0.155, rport:5060 with laddr:192.168.0.250
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x30A0EC1C
Jan  9 14:47:25.018: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x30A0EC1C, addr=192.168.0.155, port=5060, local_addr=192.168.0.250, connId=2 for UDP
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
Jan  9 14:47:25.018: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/State/sipSPIChangeState: 0x31853220 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 2469) to the VOIP RTP library
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/sipSPIValidateStreamAddrType: stream:1, Mode : 1
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 192.168.0.250
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
    laddr = 192.168.0.250, lport = 19160, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
    src_callid = 2469, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
    media_ip_addr =  - , vrf tableid = 0 media_addr_type = 1
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/sipSPICreateRtpSession: sess: 2B8688C4 do_rtcp:0
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Media/sipSPICreateRtpSession: stun is disabled
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/State/sipSPIChangeStreamState: Stream (callid =  2469)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Info/sipSPIUpdateCallEntry:
Call 2469 set InfoType to SPEECH
Jan  9 14:47:25.018: //2469/AD3510ED82D1/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:745@192.168.0.155:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.250:5060;branch=z9hG4bK109491B
To: <745>
Date: Mon, 09 Jan 2012 14:47:25 GMT
Call-ID: ADA2EE8A-3A0711E1-82D6EEFB-5980959F@192.168.0.250
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2905936109-0973541857-2194796283-1501599135
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1326120445
Contact: <2101>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 299
v=0
o=CiscoSystemsSIP-GW-UserAgent 8073 5726 IN IP4 192.168.0.250
s=SIP Call
c=IN IP4 192.168.0.250
t=0 0
m=audio 19160 RTP/AVP 0 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Jan  9 14:47:25.026: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.0.155]:5060, local_address:[192.168.0.250]
Jan  9 14:47:25.026: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Jan  9 14:47:25.026: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2AF65B4C
Jan  9 14:47:25.026: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2AF65B4C, addr=192.168.0.155, port=5060, local_addr=192.168.0.250, connid=2, transport=UDP
Jan  9 14:47:25.026: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Jan  9 14:47:25.026: //2469/AD3510ED82D1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <745>
CSeq: 101 INVITE
Via: SIP/2.0/UDP 192.168.0.250:5060;branch=z9hG4bK109491B;rport=54412
Server: Linksys/SPA9000-6.1.5
Allow-Events: talk, hold, conference
Content-Length: 0
Jan  9 14:47:25.026: //2469/AD3510ED82D1/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Jan  9 14:47:25.026: //2469/AD3510ED82D1/SIP/State/sipSPIChangeState: 0x31853220 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [192.168.0.155]:5060, local_address:[192.168.0.250]
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x2AF65B4C
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x2AF65B4C, addr=192.168.0.155, port=5060, local_addr=192.168.0.250, connid=2, transport=UDP
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 486 Busy Here
To: <745>;tag=d9950e59a7eb5288i2
CSeq: 101 INVITE
Content-Length: 0
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/ccsip_offer_ans_handle_call_active:
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/ccsip_offer_ans_process_event:
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/State/ccsip_cnfsm_debugs: OA:cur_container:ccsip_offer_ans_main_container, cur_state:S_SIP_EARLY_DIALOG_OFFER_SENT, event:E_SIP_DIALOG_ESTD
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/ccsip_offer_ans_process_event: O/A - cnfsm ret 2
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/sipSPISendAck: Associated container=0x2C2C0748 to Ack
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is FALSE
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Transport/sipSPITransportSendMessage: msg=0x32633380, addr=192.168.0.155, port=5060, sentBy_port=0, local_addr=192.168.0.250, is_req=1, transport=1, switch=0, callBack=0x0
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:192.168.0.155, rport:5060 with laddr:192.168.0.250
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x32633380
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x32633380, addr=192.168.0.155, port=5060, local_addr=192.168.0.250, connId=2 for UDP
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/act_recdproc_new_message_response: Received a 4/5/6xx message with StatusCode: 486
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[2469], src[4]
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(17) for outgoing call
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/ccsip_ipip_media_service_get_event_data: Event id = 26
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/State/sipSPIChangeState: 0x31853220 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/ccsip_call_statistics: Requesting stats for callid=2469
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/ccsip_call_statistics: Stats request failed for callid=2469, dstCallID=-1, rc=-7
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Jan  9 14:47:25.030: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/Session-Timer/sipSTSLMain:
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:2336256 ConnTime 0
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Media/sipSPIDestroyRtpSession: stream:30E12D0C
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/State/sipSPIChangeState: 0x31853220 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x31853220
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 2101
Called Number            : 745
Source IP Address (Sig  ): 192.168.0.250
Destn SIP Req Addr:Port  : 192.168.0.155:5060
Destn SIP Resp Addr:Port : 192.168.0.155:5060
Destination Name         : 192.168.0.155
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.0.250
Source IP Port    (Media): 19160
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 17
Disconnect Cause (SIP)   : 486
Jan  9 14:47:25.030: //2469/AD3510ED82D1/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 9A5
Jan  9 14:47:25.034: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:745@192.168.0.155:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jan  9 14:47:26.962: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnAgeing: Holder=0x309E1C68 Connection=0x2B2D0A48, addr=192.168.0.155, port=5060, connid=2 has been REFRESHED
Jan  9 14:47:26.962: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x309E1C68,addr=192.168.0.155
Jan  9 14:47:27.622: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[2293] removed.
Jan  9 14:47:27.622: //2467/9B5C957682CB/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
Jan  9 14:47:27.622: //2467/9B5C957682CB/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x3186F3D0 key=9BDAEDAC-3A0711E1-82D0EEFB-5980959F@192.168.0.250
Jan  9 14:47:27.622: //2467/9B5C957682CB/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Jan  9 14:47:27.622: //2467/9B5C957682CB/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Jan  9 14:47:27.622: //2467/9B5C957682CB/SIP/Info/ccsip_offer_ans_delete:
Jan  9 14:47:27.622: //2467/9B5C957682CB/SIP/Info/ccsip_iwf_delete:
Jan  9 14:47:27.622: //2467/9B5C957682CB/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 3186F3D0
Please read my post above and do what is asked in there.
Hi Paolo,
Sorry for the late reply but I was sick in bed.
Kindly find below the output you requested:
Jan 27 08:43:31.840: //2583/D2EBD32596F2/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:747@192.168.0.155:6060 SIP/2.0
Via: SIP/2.0/UDP 192.168.30.250:5060;branch=z9hG4bK647A8
To: <747>
Date: Fri, 27 Jan 2012 08:43:31 GMT
Call-ID: D37C7A6C-47F911E1-96F7CB10-21D3CAB4@192.168.30.250
Min-SE:  1800
Cisco-Guid: 3538670373-1207505377-2532494096-0567528116
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1327653811
Contact: <2402>
Expires: 180
Content-Length: 302
v=0
o=CiscoSystemsSIP-GW-UserAgent 3491 4172 IN IP4 192.168.30.250
s=SIP Call
c=IN IP4 192.168.30.250
t=0 0
m=audio 17540 RTP/AVP 0 100 101
a=fmtp:100 192-194
a=fmtp:101 0-16
a=ptime:20
Jan 27 08:43:31.848: //2583/D2EBD32596F2/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
To: <747>;tag=60b7acd9-0
CSeq: 101 INVITE
Via: SIP/2.0/UDP 192.168.30.250:5060;branch=z9hG4bK647A8;rport=57513
Content-Length: 0
Jan 27 08:43:31.852: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:747@192.168.0.155:6060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length:
Hi Paolo,
There was a misconfiguration on the ports.
I changed the port to the defaults of 5060 and here is the new output. The error changed from forbidden to user busy
Jan 27 08:46:08.192: //2585/3012E03596F8/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:747@192.168.0.155:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.30.250:5060;branch=z9hG4bK64820B
To: <747>
Date: Fri, 27 Jan 2012 08:46:08 GMT
Call-ID: 30AD4B2D-47FA11E1-96FDCB10-21D3CAB4@192.168.30.250
Min-SE:  1800
Cisco-Guid: 0806543413-1207570913-2532887312-0567528116
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1327653968
Contact: <2402>
Expires: 180
Content-Length: 300
v=0
o=CiscoSystemsSIP-GW-UserAgent 88 8727 IN IP4 192.168.30.250
s=SIP Call
t=0 0
m=audio 17634 RTP/AVP 0 100 101
a=fmtp:100 192-194
a=fmtp:101 0-16
a=ptime:20
Jan 27 08:46:08.196: //2585/3012E03596F8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <747>
CSeq: 101 INVITE
Via: SIP/2.0/UDP 192.168.30.250:5060;branch=z9hG4bK64820B;rport=55547
Content-Length: 0
Jan 27 08:46:08.200: //2585/3012E03596F8/SIP/Msg/ccsipDisplayMsg:
Received:
To: <747>;tag=7aeab9128827f7fi2
CSeq: 101 INVITE
Content-Length: 0
Jan 27 08:46:08.204: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:747@192.168.0.155:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Hi Paolo,
It turns out that there is something weird in SPA functionality where it ony allows to dial the userID extension configured on the trunk (aka line number).
I was dialing another extension and it was giving the Busy here error.
I will try to search how to route many DID numbers to the SPA9000
From my experience, the SPA devices are of disappointng quality.
Maybe is better if you only use CME.
663
