Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CME ios upgrade permanent license impact
Have 2921 router with permanent license for uck9. Upon upgrading ios from cme 8.1 to 8.8 version, need to accept EULA and went to 60days evaluation.
From research, the Evaluation license automatically rolls over into Right to use license  after 60 days of evaluation period. No further intervention is required  for this rollover to happen.
Has anyone successfully waited 60days and experienced  no problems with it.
I have to make sure as the router is on remote site that can't be easily accesible.
Jeff
1 ACCEPTED SOLUTION
Bronze
Hi Jeff,
Yep, I had several of those licenses expired just a month ago. Had no issues at all.
Boris
_____ Please rate helpful posts Пожалуйста оценивайте полезные сообщения
1 REPLY
Bronze
Hi Jeff,
Boris
242
