CME - IP Phonse stuck in Regitering oftenly
We have CME Version=7.1
IOS version c2900-universalk9-mz.SPA.150-1.M1.bin on CISCO2921/K9
7941 SCCP41.9-2-3S
Therea re 50 phones connected to the network, Oftenly 7941 phones are unregistering and registering back after some time.
Some phones stuck in registering for couple of hours and coming back and register with CME.
This is happening for many IP phones.
I see #sh ephone unregistered -- shows many phones as below, is it an issue?
ephone-52[51] Mac:0027.0DBF.24DB TCP socket:[-1] activeLine:0 whisperLine:0 UNRE
GISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 res
et_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0 0 Unknown 0  keepalive 0 max_line 0 available_line 0
Preferred Codec: g711ulaw
Any suggestion ?
Rgds
Rajesh Kumar
Everyone's tags (1)
Hi Rajesh Kumar,
Did you run "create cnf-files" under telephony-service to generate the xml files it's
looking for?
Anand
Pls rate helpful posts!!
Hall of Fame Super Gold
You may have a nwtwork problem, even if not apparent. Check switches, STP, and the rest.
222
