cme - issue with call forward all to external number when call from internal number to internal number
lguyomard
I've an issue with call forward all to external number on CME 8.6, when I make a call from PSTN number to an ephone-dn which has call-forward all to pstn number no problem but when I make a call from an internal number to the same ephone-dn the call-forward all doesn't work, the voice TELCO is telling me the external phone number doesn't exist. Have you got a solution ?
Thank you for your help,
Best regards,
Ludovic GUYOMARD
acampbell
Can you post
show telephony-service
Alex
Regards, Alex. Please rate useful posts.
Here's the telephony-service
telephony-service
protocol mode ipv4
sdspfarm units 10
sdspfarm transcode sessions 30
srst mode auto-provision all
srst ephone template 1
srst ephone description Cisco Unified CME SRST Fallback : Nov 09 2011 14:35:18
srst dn template 1
authentication credential admin exprimm
em keep-history
xml user admin password exprimm 15
max-ephones 100
max-dn 100 no-reg primary
ip source-address 172.16.120.125 port 2000
service phone WebAccess 0
service phone webaccess 0
service phone webAccess 0
timeouts interdigit 5
system message FitchRatings
url directories
http://172.16.120.125/localdirectory
url services
http://172.16.120.124/voiceview/common/login.do
url authentication
http://172.16.120.125/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
user-locale FR load CME-locale-fr_FR-French-8.6.2.4.tar
network-locale FR
load 7937 P00503010800.bin
load 7942 SCCP42.9-1-1SR1S.loads
load 7962 SCCP42.9-1-1SR1S.loads
time-zone 23
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 01442991.. extension-length 3 extension-pattern 1..
dialplan-pattern 2 01442992.. extension-length 3 extension-pattern 2..
voicemail 8888
max-conferences 16 gain -6
call-park system application
call-forward pattern .T
call-forward pattern 1..
call-forward pattern 2..
call-forward system redirecting-expanded
moh music-on-hold.au
multicast moh 239.23.4.10 port 2000
web admin system name admin secret 5 $1$H8yz$PsBfKfAJ1TOvZ5OAMkDtV.
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 0.T
transfer-pattern 20
transfer-pattern 1..
transfer-pattern 2..
telephony-service
protocol mode ipv4
sdspfarm units 10
srst dn template 1
em keep-history
max-ephones 100
url directories http://172.16.120.125/localdirectory
url services
url authentication
cnf-file perphone
network-locale FR
time-zone 23
time-format 24
voicemail 8888
dn-webedit
time-webedit
transfer-pattern .T
transfer-pattern 20
Can you try adding this line to the config
telephony-service
forward local-calls
HTh
Alex
paolo bevilacqua
Take "debug isdn q3931" with "term mon".
