CME Jabber Phone Issue
I have an IP Telephony setup with CCME version 9.1 running on 2951 router.
We have recently added cisco Jabber mobile clients both Apple Iphone and Samaung Android phones to our CCME.
All the users are using Extesion mobilty for their desk phone.
We have assigned jabber for 5-6 users only.
The issue is that when Jabber is connected on the mobile phone and Extension mobility is logged in both working fine.
But When jabber is disconnected from the mobile phone then Jabber users cannot make outgoing call from their deskphone and they are not receiving any incoming calls.
They are getting a busy signal for incoming and in the desk phone also showing busy when they make outgoing calls.
When the issue is happening we can see that the MWI button is ON and the line button shows red for their deskphone.
We gave the same Directory  number for desk phone and Jabber.
When I delete the Jabber configuration for the users and re configure the Jabber it will work for 4-5 days and again the same issue will come.
like for example:
no voice register dn 31
no voice register pool 31
voice register global
create profile.
Then re configure :
number 1330
name Abbas Jabber
shared-line max-calls 6
label Abbas Jabber
registration-timer max 720 min 660
busy-trigger-per-button 6
id mac 78A3.E4E2.F706
session-transport tcp
type CiscoMobile-iOS
number 1 dn 31
dtmf-relay rtp-nte sip-kpml cisco-rtp sip-notify
username ar password 503
description Abbas Jab
Voice register global
create profile
Rest of the non jabber users phones are working fine without any issue.
Below is the Configuration for the Jabber and attached is the running configuration for the CCME.
mode cme
source-address 192.168.0.2 port 5060
max-dn 200
max-pool 50
load 7960-7940 cmterm-7941_7961-sip.9-1-1SR1
authenticate register
timezone 31
hold-alert
dialplan-pattern 1 17101... extension-length 4
voicemail 7777
tftp-path flash:
file text
create profile sync 0738680720206537
video
number 1330
name Abbas Jabber
label Abbas Jabber
number 1 dn 31
voice user-profile 42
user ar password 503
number 1330 type normal
speed-dial 1 1344 label "Nehad"
ephone-dn  31  octo-line
number 1330
pickup-group 2
label Abbas Al Radhi
name Abbas Al Radhi
shared-line sip
call-forward busy 7777
call-forward noan 7777 timeout 10
telephony-service
sdspfarm units 3
sdspfarm tag 1 CME-CONF
conference hardware
no auto-reg-ephone
authentication credential cisco cisco
em keep-history
em logout 17:30
max-ephones 165
max-dn 166
ip source-address 192.168.0.2 port 2000 secondary 77.69.137.213
system message Welcome to BDO
url authentication http://192.168.0.2/CCMCIP/authenticate.asp
load 7916-24 B016-1-0-2.SBN
load 7941 SCCP41.9-1-1SR1S.loads
load 7945 SCCP45.9-1-1SR1S.loads
load 7965 SCCP45.8-3-5S
time-zone 31
voicemail 7777
max-conferences 8 gain -6
moh "music-on-hold.au"
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
Thanks in advance
Nithin Louis.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
When things work for a while then break, it's a bug.
So you have to contact the TAC for a fix.
Hi Paolo,
Your point is correct.Its a bug.CME only support Jabber on Windows and MAC.It was supported before and face lots of issues in Apple Iphone and Android.Now cisco has revert back the support for Iphone and Android in CME.
Thanks & Regards
Nithin Louis.
So you are saying there is no
So you are saying there is no way to configure Cisco JAbbe for iPhone and deksphone integration?
regards
Hi,Yes. CME does not support
Yes. CME does not support Jabber on Iphone and Android. CME only supports Jabber on MAC and Windows. It was supported earlier CME versions, now  withdrawn complete support due some compatibility issue jabber software.
++ CUCM supports Jabber on IPhone and Android.
Please refer below CME compatibility matrix. You don’t see Jabber on Iphone and Jabber on Android in the supported device.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme10spc.html
The only option available is to use CUCM.
Thanks & Regards
Nithin Louis
343
