Community Member
CME License on 3945
Dear NetPro gurus,
I have a brand new Cisco 3945 CME router on a customer site.  However, when i checked the license, it says the CME-SRST will expire in 58 days even though i have the following:-
- Uck9 as Permanent License
- I also have the FL-CME as well as FL-CME-SRST-100 but both i have only got a "Entitlement Qty of 1", but there is no PAK code.
So how can i activate and change it to permanent? as i don't want my CME to suddenly de-activate in 58 days.
ce-e03-1#sh ver
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.2(2)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 29-Feb-12 23:44 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
ce-e03-1 uptime is 23 hours, 3 minutes
System restarted at 13:03:13 AEST Wed May 23 2012
System image file is "flash0:c3900-universalk9-mz.SPA.152-2.T1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 1835264K/261888K bytes of memory.
Processor board ID FGL161613SZ
5 Gigabit Ethernet interfaces
20 Serial interfaces
3 terminal lines
2 Channelized E1/PRI ports
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
   Cisco Unity Express 8.5.1 in slot/sub-slot 0/0
1 Services Module (SM) with Services Ready Engine (SRE)
   Cisco WLAN Controller 7.0.116.0 in slot/sub-slot 1/0
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
2000880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C3900-SPE150/K9       FOC16145MWA
Technology Package License Information for Module:'c3900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
ce-e03-1#
ce-e03-1#sh license all
License Store: Primary License Storage
StoreIndex: 0   Feature: ipbasek9                          Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
StoreIndex: 1   Feature: uck9                              Version: 1.0
License Store: Built-In License Storage
StoreIndex: 0   Feature: securityk9                        Version: 1.0
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        License Priority: None
        License State: Inactive
StoreIndex: 2   Feature: datak9                            Version: 1.0
StoreIndex: 3   Feature: gatekeeper                        Version: 1.0
StoreIndex: 4   Feature: SSL_VPN                           Version: 1.0
        License Count: 0/0  (In-use/Violation)
StoreIndex: 5   Feature: ios-ips-update                    Version: 1.0
StoreIndex: 6   Feature: SNASw                             Version: 1.0
StoreIndex: 7   Feature: cme-srst                          Version: 1.0
            Evaluation period left: 8  weeks 2  days
            Period used: 1  day  2  hours
            Transition date: Jul 22 2012 09:18:32
        License Count: 365/0  (In-use/Violation)
        License Priority: Low
StoreIndex: 8   Feature: WAAS_Express                      Version: 1.0
StoreIndex: 9   Feature: UCVideo                           Version: 1.0
ce-e03-1#
Any help will be greatly appreciated.
Cheers,
Hunt
Everyone's tags (3)
CME License on 3945
Hi Hunt Lee,
Please refer the below thread on the same discussion.
https://supportforums.cisco.com/thread/2075659
Hope it helps.
Anand
Pls rate helpful posts !!
Hall of Fame Super Red
CME License on 3945
Hi Hunt,
I'll just add this reference to the great tips from Anand (+5 )
The license for CME-SRST will change to permanent after 60 days so you are good to go! This has been confirmed in our recent use and is also detailed in the doc below
Activating CME-SRST Feature License
The ISR-G2 comes with a 60-day evaluation license. After 60 days, the license changes to “right to use”.
The customer is required to pay for the CME-SRST feature license which is valid for 12 years.
Prerequisites
• UCK9 license
• ISR-G2 already accepts UC CLIs
SUMMARY STEPS
1. show license detail cme-srst
2. configure terminal
3. license accept end user agreement
4. exit
5. show license detail cme-srst
6. write mem
DETAILED STEPS
Command or Action Purpose
Step 1 show license detail cme-srst
Example:
Router# show license detail cme-srst
Displays the available cme-srst license. EULA should be in NOT
ACCEPTED state.
Step 2 configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3 license accept end user agreement
Example:
Router(config)# license accept end user
agreement
Configures a one-time acceptance of the EULA for cme-srst
license.
Accepts EULA by typing YES.
Step 4 exit
Example:
Router(config)# exit
Exits global configuration mode.
Step 5 show license detail cme-srst
Example:
ACCEPTED state.
Step 6 write mem
Example:
Router# write mem
Saves configuration.
Command or Action
This is explained in more detail starting on Page 15;
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.pdf
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
2027
