CME License Requirements (2901)
johnhart
Hi Cisco Unified Comms,
I have a Cisco 2901 for which I have recently purchased and installed a SL-29-UC-K9 License PAK.
However when I go into voice register global configuration I get the following license notice:
# voice register global
# max-pool 20
PLEASE  READ THE  FOLLOWING TERMS  CAREFULLY. INSTALLING THE LICENSE OR
LICENSE  KEY  PROVIDED FOR  ANY CISCO  PRODUCT  FEATURE  OR  USING SUCH
PRODUCT  FEATURE  CONSTITUTES  YOUR  FULL ACCEPTANCE  OF  THE FOLLOWING
TERMS. YOU MUST NOT PROCEED FURTHER IF YOU ARE NOT WILLING TO  BE BOUND
BY ALL THE TERMS SET FORTH HEREIN.
Use of this product feature requires  an additional license from Cisco,
together with an additional  payment.  You may use this product feature
on an evaluation basis, without payment to Cisco, for 60 days. Your use
of the  product,  including  during the 60 day  evaluation  period,  is
subject to the Cisco end user license agreement
http://www.cisco.com/en/US/docs/general/warranty/English/EU1KEN_.html
If you use the product feature beyond the 60 day evaluation period, you
must submit the appropriate payment to Cisco for the license. After the
60 day  evaluation  period,  your  use of the  product  feature will be
governed  solely by the Cisco  end user license agreement (link above),
together  with any supplements  relating to such product  feature.  The
above  applies  even if the evaluation  license  is  not  automatically
terminated  and you do  not receive any notice of the expiration of the
evaluation  period.  It is your  responsibility  to  determine when the
evaluation  period is complete and you are required to make  payment to
Cisco for your use of the product feature beyond the evaluation period.
Your  acceptance  of  this agreement  for the software  features on one
product  shall be deemed  your  acceptance  with  respect  to all  such
software  on all Cisco  products  you purchase  which includes the same
software.  (The foregoing  notwithstanding, you must purchase a license
for each software  feature you use past the 60 days evaluation  period,
so  that  if you enable a software  feature on  1000  devices, you must
purchase 1000 licenses for use past  the 60 day evaluation period.)
Activation  of the  software command line interface will be evidence of
your acceptance of this agreement.
ACCEPT? [yes/no]:
Given that I have a valid UC license why is it telling me I need additional license?
Prior to purchasing the UC license to enable the UC evaluation licence so I could start using UC and establish a correct configuration.
Is a license issue causing me to have this problem with getting SIP phone to REGISTER:  https://supportforums.cisco.com/message/3665941#3665941
Here is the show license result from router:
License UDI:
Device#            PID                              SN
*0              CISCO2901/K9          XXXXXXXXX
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
Thanks in advance.
John.
Chris Deren
You just needed to accept the user agreement, it is expected. You are good to go now.
Chris
Chris Deren
Chris
Thanks Chris,
yes I did a bit more reading and as you indicated I just needed to accept the license prompt.
Previously I set up my CME configuration via Cisco Configuration Professional and it set things up as "mode cme".
But as I have had problems with this configuration and the SIP REGISTER, I wiped the configuration and started again via ios command line.
With the command line configuration I did not do a "mode cme" and so the configuration seems to have defaulted to "mode cme-srst" which has resulted in reason for prompt.
My reading indicates that as long as I am within limit of "max-pool 25" then I should be ok license wise, however I have since set "mode cme" as I believe this reflects what I am trying to do, which is to create a SMB SIP hub which handles REGISTER and local SIP network as well as allowing me to create SIP trunks out to SIP Service Providers and my own Cisco SPA for PSTN integration.
Thanks for the assurance.
Cheers,
John.
