CME Licensing
Hi Everyone,
we are having 2851 cme router with 12.4 version of ios and 3.3 cme version.
now we are plannig to upgrade the RAM by 256MB & cme 8.6/ IOS 15.4
My question is about the Licenses..do we need to install the licenses again?
we are having 30 end user licenses and 30 voicemail licenses.
and what if my CME-Router is not having Smartnet/out-of-warrenty.
AMOD
1 ACCEPTED SOLUTION
VIP Purple
Hi , you can refer the
Hi ,
you can refer the ordering guide Table 3.18 which says
Customers who want to upgrade the Cisco Unified Communications Manager Express version must
upgrade the Cisco IOS Software version running on the Cisco IOS Router. Customers who have a
current Cisco SMARTnet contract for the router can apply for a Cisco IOS Software upgrade using the
Cisco.com Product Upgrade Tool, which can be found under support tools at
http://www.cisco.com/go/support.
Customers without a current Cisco SMARTnet contract need to purchase a Cisco IOS Software
feature set upgrade product number for their current router
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6789/ps5745/ps5520/ucme_8_6_ue_8_5_ucc_og.pdf
further, 15.1.4M ipvoice image requires 512MB DRAM  with 64MB Flash.
http://software.cisco.com/download/release.html?mdfid=279120819&flowid=7541&softwareid=280805680&release=15.1.4M8&relind=AVAILABLE&rellifecycle=MD&reltype=latest
regds,
aman
Hi Amod,Please check the
Hi Amod,
Please check the following post
https://supportforums.cisco.com/discussion/11438896/about-upgrade-cmecue-licensing-questions
Manish
VIP Purple
Hi ,
regds,
aman
209
