CME Line Descriptions - Easy Question
kylebrogers
Level 4
Level 4
How do I get line descriptions on the phones in CME?  NAME and DESCRIPTION under the ephone-dn doesn't do it.  Basically I just need button 4 to say "Front Desk 5000" rather than simply the extension "5000".
Rob Huffman
Hi Kyle,
These are called "Labels" in CME
SCCP: Creating Labels for Directory Numbers
To create a label to display in place of the number next to a line button, perform the following steps.
Prerequisites
Directory number for which the label is to be created is already configured. For configuration information, see the "SCCP: Creating Directory Numbers" section.
SUMMARY STEPS
1. enable
2. configure terminal
3. ephone-dn dn-tag
4. label label-string
5. end
DETAILED STEPS
Command or Action
Purpose
Step 1
enable
Example:
Router> enable
Enables privileged EXEC mode.
Enter your password if prompted.
Step 2
configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3
ephone-dn dn-tag
Example:
Router(config)# ephone-dn 1
Enters ephone-dn configuration mode.
dn-tag—Unique sequence number that identifies the ephone-dn to which the label is to be associated.
Step 4
label label-string
Example:
Router(config-ephone-dn)# label user1
Creates a custom label that is displayed on the phone next to the line  button that is associated with this ephone-dn. The custom label replaces  the default label, which is the number that was assigned to this  ephone-dn.
label-string—String of up to 30 alphanumeric characters that provides the label text.
Step 5
end
Example:
Router(config-ephone)# end
Returns to privileged EXEC mode.
What to Do Next
If you are done modifying parameters for phones in Cisco Unified CME, generate a new configuration file and restart the phones.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1027739
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
Rob Huffman
Hi Kyle,
Prerequisites
SUMMARY STEPS
1. enable
3. ephone-dn dn-tag
5. end
DETAILED STEPS
Command or Action
Purpose
Step 1
enable
Example:
Router> enable
Step 2
configure terminal
Example:
Step 3
ephone-dn dn-tag
Example:
Step 4
label label-string
Example:
Step 5
end
Example:
What to Do Next
Cheers!
Rob
- Stones
Excellent.  Thanks.
