CME Local directory
I am running CME 4.0.3 on a 2811. I am having problems getting the local directory option to show via the 7961 phone. It just gives "host not found" message, all other services on the system are working fine. Any ideas?
1 REPLY
Hall of Fame Super Red
Re: CME Local directory
Hi Neil,
Have a look at setting up a directories;
Cisco CallManager Express 3.2: Configuring Directories
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide_chapter09186a00802d23f9.html
Also have a look at this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_command_reference_chapter09186a0080611961.html#wp1056637
You only need to configure a url if you don't want to use the local directory. Have a look;
The Cisco CME system automatically creates a local phone directory according to the telephone numbers that are assigned during ephone-dn configuration. Additional entries to the local Cisco CME directory can be made using the directory entry command. The additional numbers can be nonlocal numbers, such as telephone numbers of other Cisco CME systems used by the same corporation.
By default, the router automatically uses the local directory service. Provisioning the directory URL to select an external directory resource disables the Cisco CME local directory service. You can also disable the local directory by entering the no service local-directory command.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad85d.html#wp2175456
telephony-service
Example:
Router(config)# telephony-service
Enters telephony-service configuration mode.
Step 2
Example:
Router(config-telephony)# service local-directory
enables local directory service on IP phones.
Step 3
exit
Example:
Router(config-telephony)# exit
Hope this helps!
Rob
3283
