CME loggin in message stays on phone
scoe
Hi All,
CME version 7.0(1) with extension mobility. Just been upgrade from 4.2 and now when user logs into the phone ays "logging in" as usual but when the profile comes up the "logging in" message stays on the phone screen until they press exit. Then it clears and it's ok. Same with logging out - the "logging out" message stays there.
I've upgraded the phone loads to the correct version.
Anyone seen this before?
Stuart
Rob Huffman
Hi Stuart,
There is a bug listed and a recommended IOS in this good post from
Java @ Cisco;
https://supportforums.cisco.com/message/3027218#3027218
Cheers!
Rob
Hi Rob,
Yes that's sounds just like it. The bug says it's fixed in 12.4(22)T2 but this CME is already on 12.4(22)T3 .
Unless Cisco unfixed it in T3.
Thanks for the reply anyway.
Stuart
Hi Stuart,
You are most welcome my friend
Just as an FYI, I just went through a similar "versioning" question
on another Cisco product. We were on a newer version than the
"fixed-in" version and the bug-fix was not in the newer version. It
had been missed and we actually needed to downgrade or get an ES.
Cheers!
Rob
