CME Media Resource Configuration?
Hi All,
I have a 39XX router as cme and cue (40 phone regiter it). That router is just connected to PSTN. So At this point I think that I dont have to make media resource configuration like blow. am I right ? or Which configuration should I make. I will just using voice not video. And If I dont make media resource configuration how my media resource will be concumed?
voice-card 0
no dspfarm
voice-card 1
no dspfarm
dsp services dspfarm
sccp local GigabitEthernet0/0
sccp ccm 10.15.15.1 identifier 1 version 4.1
sccp ccm group 1
associate ccm 1 priority 1
associate profile 101 register confer1
associate profile 103 register xcode1
dspfarm profile 103 transcode
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 6
associate application SCCP
dspfarm profile 101 conference
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 5
Hall of Fame Super Silver
Re: CME Media Resource Configuration?
What media are you referring to?
Your config is for transcoders, but do you need them?
And hardware conference bridges which are nice to have as software CME bridges only allow 3 participants.
Chris
Hi ,
Transcoding is not required if you only going to connect with PSTN . You can define the conference resource based on the no of attendes in the conference.
If you want more than 3 participants in the conference you require Hardware Confernce ( dspfarm Profile) required
Blue
You do not need media resource if you only need normal PSTN calls. Media resoutce are required when you want
conference, transcode  or mtp ( Media Termination point ).
regards
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
639
