CME & Mobile Access, SNR
Hello I have installed CME 7.1 and I was wondering if the Mobile Access feature is included here if so how do you configure it ?
I also have SNR enabled when i try to transfer a call from my ip phone to my remote destination, when i press the mobility softkey nothing happens and this is what i see on the gateway
fStationSoftKeyEventMessage 6316 unknown press mobility key 37
what's wrong ?
thank you
Re: CME & Mobile Access, SNR
Configuring Single Number Reach
This chapter describes the Single Number Reach (SNR) feature in Cisco Unified Communications Manager Express (Cisco Unified CME) 7.1 and later versions.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
thanks
i got SNR working my problem is when i want to transfer the call from the ip phone to the remote phone (cell) when the call is connected and i press the mobility key this is what i get on cme
000918: Jan 22 17:41:36.099: fStationSoftKeyEventMessage 6316 unknown press mobility key 37
which debug or what do i need to do to get this working
thanks
516
