CME multiple SIP providers
npservice
Hi at all,
I would like to configure multiple sip trunk on cme 4. There is any way to this?
Thanks, Bye!
paolo bevilacqua
Yes, but there are issues for authentication.
The ideal would be to be assigned the same username and password for both, I realize this may be impossible.
Thanks for your response,
look my config below:
dial-peer voice 1 voip
preference 1
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target dns:voip.eutelia.it:5060
dtmf-relay rtp-nte
dial-peer voice 2 voip
preference 2
destination-pattern 5T
voice-class codec 1
session target dns:sip.messagenet.it:5061
incoming called-number 5311402
sip-ua
authentication username 053* password *
no remote-party-id
registrar dns:voip.eutelia.it:5060 expir 3600
sip-server dns:voip.eutelia.it:5060
I have noticed that I can configure only 1 registrar and only 1 sip-server on sip-ua config.
Let me know if there is another method to do this, I would like to use 2 or 3 registrar an sip-server...
Thanks, Bye!!!
