cme MWI not working
We have a running CME - CUE system, people can leave and listen voicemail without any problem, but voice message indicator on phones not working. It is always off. Both CME and CUE config are attached. Can you please check and advise.
Thank you
cme MWI not working
Hello Umit
what is the method you are using for MWI?
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
cme MWI not working
checked the config seems you have not configured it correctly, also method which you are using outcalling.
dial-peer voice 2 voip
max-conn 16
destination-pattern 77.
session protocol sipv2
session target ipv4:10.2.3.2
incoming called-number 77[89]...
dtmf-relay sip-notify
codec g711ulaw
no vad
ephone-dn  60
number 778... no-reg primary
mwi on
ephone-dn  61
number 779... no-reg primary
mwi off
Make above changes on CME config, hope this will fix your MWI issue, if didn't try debug the issue. collect the debug ccsip messages and post the same.
Br,
Nadeem
Re: cme MWI not working
I applied the corrections but still no light. "debug ccsip messages" output is attached.
132
