CME not releasing the line even when call is hanged up.
I am facing this wierd issue which came in out of no where.
Whenever I configure a line dn 2000 to call-foward noan to a mobile number after sometimes this line 2000 and sometimes all line go busy.
ephone-dn  1  dual-line
number 2000
call-forward busy 7000
call-forward noan 96617484 timeout 18
CME version is 7.1
I have attached my complete config and show call active voice output.
Please help, I am confused why this is happening.
1 ACCEPTED SOLUTION
Silver
You are having famous FXO disconnect problem and you have to fine your country specific disconnect tones...mo
http://ciscoflair.blogspot.com/2009/05/cisco-fxo-disconnect-issue.html
HTH,
Dragan
HTH, Dragan
Silver
HTH,
Dragan
HTH, Dragan
Thank you Dragan,
I will try this and confirm.
Hi Vijit,
Configure custom tone according to your country.
Please refer below link
http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/8120-fxo-disconnect.html#topic3
For tone database you may refer below link
http://www.3amsystems.com/World_Tone_Database?q=India,Disconnect_tone
Nishant Savalia
Regards, Nishant Savalia
81
