Community Member
CME on 2921, 7962G phone not registering
Hello everyone!
I'm in great need of solving the problem, and i can't, with the help of all docs and threads in Internet.
I need to make work IP phones 7962G on 2921's CME. So, i have new 2921, 3750G and 7962G phones, which are not registering on 2921.
about 2921:
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M3.bin"
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          FCZ1728620R
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
                            Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
конфиг 2921:
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
  network 10.10.10.0 255.255.255.0
  default-router 10.10.10.1
  option 150 ip 10.10.10.1
interface GigabitEthernet0/0.2
  encapsulation dot1Q 2
  ip address 10.10.10.1 255.255.255.0
telephony-service
  no auto-reg-ephone
  max-ephones 10
  max-dn 100
  ip source-address 10.10.10.1 port 2000
  cnf-file location flash:
  cnf-file perphone
  time-format 24
  date-format dd-mm-yy
  max-conferences 8 gain -6
  moh "music-on-hold.au"
  transfer-system full-consult
  create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1
  number 2200
ephone  1
  mac-address 44AD.D9D5.182A
  type 7962
phone's interface on 3750G:
interface GigabitEthernet1/0/12
  description IP Phones
  switchport trunk native vlan 3
  switchport mode trunk
  switchport voice vlan 2
  spanning-tree portfast
Phone itself keep "Registering" and showing circle.
On 2921 in debug I see:
Sep 25 10:52:28.179: TFTP: Looking for CTLSEP44ADD9D5182A.tlv
Sep 25 10:52:28.299: TFTP: Looking for ITLSEP44ADD9D5182A.tlv
Sep 25 10:52:28.431: TFTP: Looking for ITLFile.tlv
Sep 25 10:52:28.895: TFTP: Looking for SEP44ADD9D5182A.cnf.xml
Sep 25 10:52:28.899: TFTP: Opened flash:/its/vrf1/SEP44ADD9D5182A.cnf.xml, fd 9, size 1425 for process 296
Sep 25 10:52:28.903: TFTP: Finished flash:/its/vrf1/SEP44ADD9D5182A.cnf.xml, time 00:00:00 for process 296
Sep 25 10:52:33.303: TFTP: Looking for English_United_States/mk-sccp.jar
Sep 25 10:52:34.619: TFTP: Looking for United_States/g3-tones.xml
also, 2921 sees phone, but cannot register it:
#sh ephone
ephone-1[0] Mac:44AD.D9D5.182A TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0* 0 Unknown 0  keepalive 0 max_line 0 available_line 0
Preferred Codec: g711ulaw
Lpcor Type: none
In "Status messages" on the phone last messages are "Error Updating Locale".
Firmware on the phone is SCCP42.9-3-1SR1-1S. I've tried to "load 7962 SCCP42.8-5-4S", but phone (after rebooting and loading) show message "Load Rejected HC  SCCP42.8-5-4S", then it shows "VPN Not configured", firmware is still 9-3, and it still not registering.
also, i cannot download anything from cisco.com - i have no contract and nothing else that will permit me to download software. But here's what i have:
cme-full-7.1.0.0.tar
cme-full-7.1.0.1.tar
cme-151-2Tv1.zip
i've trimmed tar for 7.1.0.0 to keep there only that files:
APPS-1.2.1.SBN
apps42.8-4-1-23.sbn
cnu42.8-4-1-23.sbn
cvm42sccp.8-4-1-23.sbn
Desktops
dsp42.8-4-1-23.sbn
gui
GUI-1.2.1.SBN
jar42sccp.8-4-1-23.sbn
music-on-hold.au
ringtones
SCCP42.8-4-2S.loads
SYS-1.2.1.SBN
term42.default.loads
TNUX-1.2.1.SBN
TNUXR-1.2.1.SBN
WLAN-1.2.1.SBN
also i've extract to 2921' flash files regarding 42/62 from cme-151-2Tv1.zip (CME 8.1).
i don't think that issue is in version (although i cannot download CME 9 and therefore cannot test it)
Please, help!
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Super Bronze
no auto-reg-ephone
You need to enable it.
That is untrue. This command is only relevent if you want phones you haven't explicitly provisioned in the config to register. Furthermore, you would need to configure Extension Assigner to dole out ephone-dn assignments.
Did you run a create cnf-files after configuring the ephone? The timestamp above shows it was last done in 2002.
Note that you need to map the ephone-dn to the ephone using the 'button 1:1' command within the ephone.
What does a 'debug ephone register' output show?
Please remember to rate helpful responses and identify helpful or correct answers.
Community Member
sorry, i found the cause: i've missed "button" in ephone configuration, thought it was unnecessary word for configuring special functions on the phone's buttons. i think the problem solved, sorry again.
Community Member
Hi there.
change this command.
no auto-reg-ephone
VIP Super Bronze
no auto-reg-ephone
Community Member
Jonathan, you're absolutely correct about 'button 1:1' command, i've missed it because of a hurry and doing all 'by the book but faster'. And about timestamp 2002 - it is because i'm first start telephony-service and after it ntp server. I did 'no telephony service' and then 'telephony-service', timestamps was correct this time. And about 'button 1:1' - by fast reading documentation i thought 'button' command is for some special functions assigned to phone's button, like on avaya phones, so i missed it - my bad, and thank you!
1130
