CME one-way audio after about 5 minutes on call
Just curious if anyone has run into this or what might be the cause. I am told it is an internal dialed number from a remote site, cme to cme I believe..... After 5 minutes on call, goes to one way audio.
1 REPLY
Re: CME one-way audio after about 5 minutes on call
Had a similar issue with a CCM to remote h323 gateway. It turned out to be an IP routing problem. after 5 minutes, one way audio. Reproducable every time.
Can't remember the specifics but make sure you have solid routing all the across.
138
