Community Member
CME Outbound Caller ID
Hello All,
I know we can do this in CM but checking for CME. on a PRI we want to show outbound caller ID as 1 of 3 or 4 masking numbers for some phones and no number show at all for other phones.
Possible in CME?
Thanks in advance! All replies rated.
1 ACCEPTED SOLUTION
VIP Purple
Re: CME Outbound Caller ID
You can use the following command to block caller ID:
ephone-dn 1
block caller-id
You can use translation rules to send out varying caller ID, such as:
voice translation-rule 1
rule 1 /1000/ /1234567890/
rule 2 /2000/ /1235551212/
voice translation-profile 1
translate calling 1
voice-port 0/1/0:23
translation-profile outgoing 1
Hope this helps.
Brandon
1 REPLY
VIP Purple
ephone-dn 1
block caller-id
translate calling 1
voice-port 0/1/0:23
Hope this helps.
Brandon
763
